Mk2 front seats
I'm sure this question has been asked plenty of times before but what seats would fit into a mk2 polo with very little or no modification?
  • Views 871
you're right, this has been asked many times, use the search function next time, but anyway.
A straight swap into the front of a mk2 polo would be polo mk1,2 and 3, golf mk1 and 2, rocco and raddo. The rocco and rado seats sit nice and low, so much more sportier feeling, golf seats sit higher than polo seats, it depends on how tall you are.
As for the rears, polo ones are a straight fit, the golf ones can be fitted with some work, the rocco and raddo ones with more work.
Thanks, now just have to find myself some seats think ill go with rocco seats if i can get some
just to check though, what year is your polo?
what i wrote applies to the spanish built mk2's (from 86 onwards i think).
Its an '83 had an '87 though and it wasn't spanish built
Any seats will fit, depends what work you want to put into it.
I have a set of Vauxhall Astra GTE seats in mine, welded on standalone subframe with polo runners and the seats just bolt into it.
well the lever for moving the seat forwards and backwards was switched to the other side on the spanish built cars, therefore with an 83 car the seats i said will still fit, you'll just have to reach under the seat and pull the pin to move it.
