Where can I get these headlights?
Am I right are these called lm pros ? are they still available to buy whats their avarege price ? anyone knopw where cna I buy them on the net?
Can of black paint and an hour or two.
Remove the lights from the car, heat them up remove the front lens, unscrew the surround, sand them down a little, then paint them. For the indicators same process, only you have to mask off the back ( as in the picture the back of the lights are still silver) then paint them. A bit more heat to seal them up and then refit.
Thank my lights are extremely yellow so I will be buying a set of new ones form ebay and hopefully if i can get them split without breaking them i will do what u said. I suppose heat resistant paint has to be used.
Not really, normal black, either Matt, satin or glos (up to you) you could use a primer if you wanted, this will make it less likely to crack, and you could also use a clear coat.
The polo lights IMO are really easy to open, I have open my passengers side one today and it took me less then ten minutes. I used a paint stripper heat gun.
HTH
HTH
Thanks a lot! I hope this wont have any negative effect with the MOT crowd.
