1.4 16V AFH BIKE CARB MANIFOLD FLANGES
MANIFOLD FLANGES MADE FROM MILD STEEL, READY FOR YOU TO WELD YOUR OWN BITS OF PIPE ON AND THEN ALL YOUD NEED IS SOME HOSES TO FIT THE CARBS TO IT,
I've GOT 3 AVAILABLE
CHEAP MANIFOLD, MANY PLACES CHARGE OVER 100 FOR THESE TO BE MADE.
£20 POSTED
  • Views 357
There fine just get a dremel out and cut the small top notch into it but tbf rob there the same price for the same thing with the correct inlet holes already done!
thats the proper AFH flange:
http://www.ebay.co.uk/itm/VW-POLO-16V-MK3-...57#ht_500wt_969
your got wrong shape holes!
haha what I'd like to know is where that geezer got my auto cad drawing from? I would say with 99% certainty that's one of my drawings they've used to make that.... I should charge commission..
those holes are for the injectors though which aren't needed to run bike carbs??
Edited by robbodred
if anyones interested ill do them £10 posted
you are correct about the notches on top, they are for the injectors. However, i can't see it being a good idea to simply blank them off, as there will still be a pocket of (turbulant) air behind the flange, not good for power!
Despite all this though, i'm still interested :lol:
how have they been cut out, and what thickness are they?
