front wing removal 6n
I've got a dent on the drivers side front wing and I'm tempted if i can pick up a cheap dragon green wing in good nick to just replace it, just wondering how hard it is to change?
I'm pretty technically minded just got a few jobs on the go on it and dont wanna go ripping the front end off to find bolts for it!
Any help greatly appreciated
  • Replies 10
  • Views 4.8k
Rough guess from most VW's, it's arch liner out, bolts down the back of the wing holding it into the A-pillar. Bolts along the top of the wing, and something behind the bumper.
  • 3 months later...
Sorry to revive an old thread but is there likely to be any sort of adhesive holding the wing in place?
I am replacing both my front wings (on a 6n2).
EDIT: did the OP do this in the end? Was it easy?
Edited by racer-ev
the inner bit to the rear of arch is kinda stuck in place but comes off fairly easily
its easy enough to do
Cool, thanks Harris. Gonna get onto fitting these wings then. No point hangin' around!!!!
Just getting to front bolts is awkward
Well the front bumper and headlights have got to come off for other jobs so it should not be much of a problem!
Piece of piss then haha
If you struggle let me know...so I can laugh at you ;)
Edited by harris.racing
O yeah, i'll get right on that!!
Do you think I should renew the adhesive, if so what would I need to buy?
I didn't,
I think it's the same stuff that all the seams are glued with, seam sealant may be?
