AEE decomp plate
Hey,
I'm looking at and pricing up turbo'ing my AEE on carbs for banter etc,
IIRC it's 9.5:1ish standard.
Think mine calculated to 10.7 or 10.8 when I checked.
Are there off the shelf plates? Or do I need to get one made using a HG as a template?
Also does anyone know the thickness of a standard head gasket once the heads torqued? I lost my sheet of measurements.
Obviously I'm going to gain the thickness of the decomp plate and another HG. I think around 8-8.5:1 will be ideal, so I can calc the extra volume increase.
Also, does anyone know if ARP offer conrod bolts for These engines? Though 20vt ones may work come to think of it - may aswel change them when the sump is off whilst I'd be fitting the oil drain.
Nick
  • Replies 58
  • Views 4.2k
Was looking at doing the same to my AKL. I had a read through this thread on ukMkIVs which was quite helpful.
Golf Mk4 1.6T
Not sure which page its on but he does say he got a decomp plate and gives a web address for where he got it from.
I believe it was made by copying the HG and was made to the thickness he wanted for a certain compression ratio,
Cometic do a range of different thickness head gaskets for almost every engine, If they dont have it in their catalogue, they'll make it, Click Me I used them for my VR6, better option that 2x gasket with spacer inbetween.
Matt
I have a aee decomp plate I used on my 1.6 turbo I'm sure it 2mm thick but ill double check. Ill sell it if you interested in it. Dan
As above ^^^ Use ferriday engineering top quality and comes with fitting kit.
I think mine was about £180 :biggrin:
£180?! Haha I'll make one myself with a jigsaw
Found the prices on the site, they are £90 for 1" and £118 for 2"
1" what?! Thick? My comp would prob be like 2:1 haha
I'm guessing he means mm lol not inches and search eBay for polo decompression Harris and see if one of the two that comes up match your head as I'm gunna look at one of them two for my afh if one is right or close need only like 40 quid roughly
Edited by StinkyPete
I'd get 2mm cause Iv raised the comp as it is.
Wonder how the pistons and rods will hold up
Got mine off ebay about £35 same as a g40 one
That's the one I'm on about on eBay and it's 1.5mm thick but you can ask for a diff thickness
Yeah, hmm! We shall see, I'm awfully tempted !
Got mine of ebay over a year ago and is exactly the same as the aee headgasket. Really well made. Dunno if they still make them.
Might fill my rods with weld for strength
^That'll make them heavier though harrris. Which wont be good for the longevity of the engine
I'll use metal set resin
Fuck knows what I was thinking when I wrote that out, yeah it was meant to be mm :lol:
All this talk of boost is making me want to keep the polo as a full on project and try turboing it. Anyone have any idea of if the standard avy bottom end can take a worthwhile amount of boost? The rods are certainly chunkier than the afh rods :lol:
Edited by Mclovin
hahaaa. Hmmmm temptations!!
Actually £120 sounds about right i did buy it over a year ago.
Guy just boost it man, bolt mechano to rods before fitting
I do know the AVY/ARC will take up to around 200bhp with around 8psi of boost before death on standard internals
