AEE decomp plate
Boost it is then :lol:
  • Replies 58
  • Views 4.2k
8 psi?! Haha I was gonna run like 15 just drop compression
your going to need to drop it quite a bit as youve raised it further than factory though? And I'm sure itll take up to 12psi but dont quote me on this as I've not seen it. on mine its a 1.4 16v AFK engine from a lupo sport and 6n2 polo sport which are 100bhp standard and a lowered compression ratio of somewhere in the 9....s also just found this info regarding the 6n2 1.4 16v engine and the 1.6 gti engine >
"The 1.6 conrods are thinner, and have a 5/16 bolt rather than a 3/8 bolt as found in the 1.4. Combined makes them alot weaker, also the 1.6 piston crown is thinner I'm told.
If you want forged for the 1.6 you want a set of JE pistons and carrillio con rods as i have the remake numbers for them. But you need to put aside alot more money than you think"
From Club lupo. :ninja:
Hahaa, water injection And a massive Intercooler, be right!!
just hacksaw a bit of the piston off. be alright :ninja:
Ill space the head 10mm and fill the top of pistons haha
10mm!!! damn bro you can only get decom plates in 2 mm max
I'll get 5!
Stack some gaskets it'll be reet
The 1.6 rods are shorter than the 1.4 ones tho, would that not make up for some of that lost thickness?
We had a 1.6 at like 350hp at college on standard comp before it broke the land between rings
A 1.6 what?
Vtec haha
Been doing some reading up this morning and some thing I've just found is this quote from caspergti on club lupo about the 1.4 internals vs 1.6
And who told you the sport internals are stronger? The pistons are the same and the rods are thinner. The only reason there considered stronger is because the sport originally has a 10.5:1 cr where the Gti is 11.5:1
So it seems there are mixed opinions on which is stronger if any :?
Would I be right in thinking that a super charger would be easier on internals given the way boost comes in with rpm rather than a big kick in the balls like with a turbo? I know turbo's a better for bigger power but I'm not after big power
i think you should be the first to make a twin charged mk2
Would I be right in thinking that a super charger would be easier on internals given the way boost comes in with rpm rather than a big kick in the balls like with a turbo? I know turbo's a better for bigger power but I'm not after big power.
Depends on what turbo and what supercharger. A G40 or G60 lader can deliver lots of boost at low rpm, which is potentially harder on the bottom end than something that comes in progressively at higher rpm. A Rotrex 'charger might be a bit more sympathetic - and so might a smaller turbo not running huge boost.
I was thinking about eaton m45's purely for the noise :lol:
I would be more interested in fitting slightly shorter rods, maybe in combination with a decomp plate. The shorter rods will give you a shorter stroke which means it will rev higher!!
If your worried about the strength the shorter rods should, in theory be stronger, obv. depending on the design/materials and such!
Only way you could be sure would be forged. HUGE monies!!!! :lol:
I think if a turbo is sized, spect and controlled correctly it will provide boost in a similar fashion to a charger.
People who complain about turbo lag just don't have it done correctly.
Yes a big turbo will provide big power but as you said that is not everything.
A smaller turbo could give you a more stable torque and power delivery therefore making it a much better car to drive and use.
Shorter rods don't give you a shorter stroke. The crank throw remains the same.
Shorter doesn't mean stronger...
If I take this route I'd rather stick with oem stuff to keep the costs down. StinkyP for example is running rebushed forged 1.8 20vt rods in his afh, for the power I want standard 1.8 20vt rods would probably be more than enough, but then that means going back to 1.4 crank.
Tbh I'd like to get more info on standard 20vt rods to see how they compare to the avy rods but google just comes up with endless threads about uprated and forged ones and very little else :?
Might fill my rods with weld for strength
That may cause problems as they may twist when you weld them and they will be out of balance too. I'm running mine at .7 bar and it's running ok at the moment with standard rods and pistons
Haha I was I only joking don't worry!
What comp ratio you running?
Not sure how much boost I could push through the bike carbs either!
Guy if my forged rods were too thick to begin with before I machines them then standard 20vt rods would be too thick too and I had a thought the other day is the 20vt crank the same piston spacing as the afh as if so you could just use the 20vt crank with the rods in an afh or gti block then it will be ready for boost nearly if you get what I mean
Or you could just put a 1.8t in it and be done with it...
