AEE decomp plate
Guy if my forged rods were too thick to begin with before I machines them then standard 20vt rods would be too thick too and I had a thought the other day is the 20vt crank the same piston spacing as the afh as if so you could just use the 20vt crank with the rods in an afh or gti block then it will be ready for boost nearly if you get what I mean
See this is the problem, I can't find any info on standard 20vt rods :lol:
Saw plenty of forged ones that were 20mm thick (weren't yours 25mm thick?) So fuck knows what the original width is. From what I've read up today the avy crank isn't an issue and nor are the standard bearings, the main weak spots are the rods although the pistons are also mentioned as being a bit weedy.
Just some random photos, top one is a set of BAM conrods, second one shows the shorter avy rod next to a afh one
I know this gives very little idea of anything but meh :lol:
Dan if the 20vt didn't mean I couldn't run my 14's I'd give it a bash :wink:
  • Replies 58
  • Views 4.2k
I'll run mine to the point of ripping apart the block, with the mad scientist...to replace the piston rings I fried
Yeah mine we're 25mm thick Guy and I never found any 20mm thick or I would have gone for them to save a lot of hassle tbh and I only meant use the 20vt crank so you can use the standard 25mm thick 20vt rods if you get me as they would be too thick for the avy or afh crank that's all I was thinking
Id say the BAM conrods are only slightly thicker lower down. Yeah Mc loving that was taken from casper and the other guy who eaton charged that lupo I'm doing pretty much the same thing right now on standard internals so we will see how long it lasts. Eaton M45 charged 6n2 AFK engine running megasquirt 2 v3 still yet to finish the wiring but getting there.
The 20v cylinder spacing is different, so you aint getting a 20v crank in a short block.
I think the way forward is 1.6 16v rods from a short block such as the AVY, BCB etc etc in the AEE block with it's deck skimmed down to the preferred height is probably gonna be the way forward.
But whether you use the 1.6 8v pistons or the stronger 1.4 8v pistons, that'll mean at least a 5mm slice chopped off the block, and i'm not sure how well the casting will take to that (even though the 1.4 8v and 1.6 16v blocks are decked even lower from factory - could be an internal casting difference i'm missing, and i'm thinking water ways and head bolt threads).
You suggesting skimming the block to accommodate the shorter rods?
if you need any info or want a set of 20vt rods, i have 2 sets on the bench, AGU and AUM, only difference is AGU has 20mm wrist pins and AUM has 19mm
That's very handy to know, both the late afh and the avy rods are 19mm wrist pins according to my tape measure. So assuming that the standard 20vt rods could be rebushed like stinkyP's forged ones it should be possible to have a afh ready for boost fairly cheaply. it seems quite common for people to uprate their 20v rods so surely it wouldn't be too hard to find a decent set of used standard ones fro sale. Guess the only question then is how strong are the standard pistons
afh or Avy block (avy oil squirters could come in handy), afh crank, new oe big and main bearings, rebushed 20vt rods and a suitable decompression plate. Afh pistons give a higher compression so may have more meat on them than avy which could be some thing to look into
Hmmmm
Edited by Mclovin
£40 if anyone want a set of rods
