supercharging my 6n
hey all,
right firstly i have 1.0l 1998 6n, could anyone tell me the engine code for this?
Secondly i want to supercharge my car, but not the 1.0l as that would be pointless and probably blow up after a few miles..
so does anyone know what excatly i would need, for example what blocks would be suitable to take a supercharger, also the engine codes for these. also what else would i need, new ecu, injectors, carb etc?
any help is greatly appreciated
many thanks Daniel
  • Replies 18
  • Views 1.3k
You will need 5-12k to do it properly, have a look round the site, there's a wealth of information available as this question has come up once or twice before.
Engine code: If you look in your boot (normally under the carpet) there should be a sticker with the chassis information on it, failing that it is stamped on the block just under the head gasket joint.
Matt
thank you both :
AFH 1.4 16V lump that came out the 6n polos are good for charging. But thats all i know, few lads on here have done the conversion, i'm sure they'll go into depth with what work is needed to get it done properly.
The afh is not good for charging its a lot of work just to get it able to take moderate boost without blowing it up and not a lot of people have done it
How about a set of 1.8 turbo rods?
The big end is the right size, the small end is 20mm. The AFH takes a 17mm pin, but you should be able to get the 1.8T rods bushed to the right size, and if you have the bushing off set you could reduce the compression at the same time as improving the rod strength.
http://www.ebay.co.uk/itm/Volkswagen-VW-Au...=item19cde35220
I am running the 20vt rods and they are far from a straight fit they need more machining than just rebushing theY need machining to make them skinnier and if you did eccentric the bush to lower the comp you would need to watch it doesn't rotate still as this could ruin the block and piston
Edited by StinkyPete
Good point Ross.
Off setting the bush isn't a great solution on reflection.
There must be a combination of stock parts that will make suitable combination.
I wish people did more research and gained a wealth of information before asking questions on things that come up time and time again. I went through pages and pages of information on here edition club lupo and all over the web gathered as much information as i possibly could read up on what was needed, compression ratios, engine blocks, etc THEN when i had enough information asked the questions i needed to know to fill in the gaps.
I know this as i am supercharging a 1.4 16v 6n2 engine as we speak and it has taken me over a year and more than 5 thousand pounds worth of parts and i am still not finished!!!!!
Should be able to g40 a 6n for less than £2k, easily reach 150bhp without to much work.
Would a 1.8t engine swap not be more effective and cheaper? Making it fit surely is a simpler solution than doing stuff to an engine that was never designed for it. You end up having to urpgrade every part as you move the weak point around. respect to those doing it. when i diy'd my mp45 on my mx-5 it wa complex enough even though the 5 can take boost from stock. You then have the "what's going to show up next" syndrome, where the next weak point doesn't show until later.
The cash and resulting output is a project not to be taken lightly.
Where have you plucked that number from? A whole g40 can be had for much less than that!
And a 1.8T is far from an easy/cheap option. Just ask panda! Charging these engines isn't really too difficult, so long as you use the correct assortment of parts, namley G40 as there are already built for FI.
As said above though, your question is too open ended. Theres more than a list of parts. You need to read the multiple threads on here about engines, engine codes, charging and turbo engines too (many isseus are similar regarding compression ratios etc). user name cheys put a fantastic thread up earlier this month about tubo'ing a 1.3 from a mk3 (same engin will fit yours). Worth a read. Also look at the build threads section
It is plucking a number yes, but having been there and done the whole charging and AFH, i would say, dont waste your money. I'll continue with mine, but its almost pointless. To go slightly in to detail, the main thing is gearboxes. To go though the hassle and money spent on charging an AFH to do it properly, it will make just as much, if not more power than a well spec'd G40 turbo. Which also means it'll shit gearboxes just as fast, if not faster. Now either shell out for custom gearbox internals (£2k and up ish) to make life easier and not shelling out for gearbox rebuilds every 1-1000 miles with the 250bhp+ animal you've built or G40 turbo it and save yourself say £5k? - No brainer really.
Gearboxes are a weak point, but it depends how you drive. Dumping all the power at once is likely to cause damage, but drive sensibly and there's no reason they shouldnt last a bit longer. Mk2/2f ones are considered stronger too
  • 3 months later...
That's because you bought the wrong 20vt rods Pete, there are much more suitable rods available as discussed in another thread a while ago. Olly (polo6n2g40) measured a couple of sets he had knocking about (AGU has 20mm wrist pins and AUM has 19mm), and I found plenty of 20mm wrist pin forged 20vt rods for sale. So rebushed standard or forged 20vt rods could be used without the need for machining material off them
Link to the thread http://www.clubpolo.co.uk/forum/index.php?showtopic=275262
Yeah I seen that Guy it was months after I had done mine though and none of the places selling the rods state the thickness so I bought and made to fit at the time
