Ryan's Tornado Red G40
Model: 1992 J Reg Polo G40
Engine: Standard with 65mm pulley and chip
Suspension: Standard
Brakes:Standard
Wheels and Tyres:Standard BBS Toyo proxes
Exterior Styling:Tornado Red
Interior Styling:G40 interior
ICE and Security:Alpine head unit with alpine dashboard speakers
Comments: I bought a G40 not that long ago at 2011 GTI fest wanting it as a project, it had the oil light flashing and buzzer going off but i got told the oil pressure was okay and it drove 2 hours home okay. Also it would not start after u turned it off when it was warm, witch i was fine with as i did not want a prefect car coz i wanted stuff to work on. So i got it back home gave it a good clean. After a few mouths after getting it i got it into a garage to keep it dry. I'm wanting a full respray inside and out full engine rebuild I'm gonna do the hole lot. if I'm gonna do a project I'm gonna to it properly and do everything.
This is it before i started any work on it.
50D5457C-659C-4910-8D82-48E17D5B5909-204
C466AF36-4045-4895-972C-1E431A35DF7C-204
E28BA0B9-5597-4EE5-98E7-74F4DEFE0E0F-204
Edited by RyanC
  • Replies 276
  • Views 42.5k
  • Few extra shots I took today. Got all the suspension tightened up today aswell then got my wheels on New genuine centre caps from Germany! Found a bag in with the mountain of polo part
  • so much new and shiny
  • Lifted the engine in with old hooks as I didn't want to damage my nice shiny re-zinced ones also fitted my dipstick that I also got zinc plated ha. Powder coated water pipe fitted, and yes all new
dont suppose the no plate ends in PDD?
So I found the two problems with the car the non start problem was earthing fault and the battery was crap, so I cleaned up the earths and put the battery off my bready and it started every time so thats that sorted. The oil light flashing and buzzing is the senders or the clocks I've checked the oil pressure and it was fine but I am rebuilding the engine top to bottom anyways. So I started to pull it apart.
Edited by RyanC
engine about to come out and then i can strip that down ready to see what in gonna do for the rebuild of it.
Edited by RyanC
I'm gonna get the body work side of things done first and then start on the engine as that is the bit i enjoy doing.
I've also ordered a stage 2 subframe and ARB blocks :)
Edited by RyanC
wow looks like a nice clean standard one. it would be a shame to alter this one too much
i used to own this, as did Rae and Dougy g40. Nice car. I rescued it (i bought it as a shell, engine and about 4 stacker boxes of parts!!!) then sold it at bvf in 2008 or 9 i think.
sweet well thanks for rescuing it coz i love the thing :D
Looking good !
bit of an update
I've taken the loom out just got to take the rack out and then take the wings off so i can clean the bay and all the other bits like the inner arches and underside.
rack now out so i took the wings off so i can sort the rust out
so i started gunking the bay and arches and then hit it with a pressure washer here is the arces and the bay after cleaning it
also clean the underside as it was covered in oil :)
and then found 2 bad bits
the battery tray under the dash has a hole after using my finger to make it so i will cut it out and weld a plate on there so thats not a problem.
and after cleaning the bay i found this crack on the os just above were the drive shaft sits i think it must of had a front ender at one point but its dented the metal out aswell :/ so when i get my subframe i dont think it will fit as the shape will be a bit differant but hopfully not. its not noticeable unless u really look but its there, I'm thinking of welding up the crack and hammering the dent back in. but it looks like it has bin there for a long time must off happend quite long ago if anyone has any ideas plz let me no what u think thanks
Edited by RyanC
Good work so far, keep it going :)
Is that crack in the chasis leg? Ouch! That must have been a pisser to find :-(
Get a weld on the crack and get a PPP subframe on it :)
That inner wing looks lovely now!
lucky you found that crack really, i wouldn't like to think id be driving round unaware of that
Edited by vwjake31
Thanks guys :) yeah when i found it i wasnt happy but i can sort it out I'm gonna drill out the end on the crack to stop it from cracking anymore the weld it up i want to ask people what they think i sould do first tho :)
Edited by RyanC
looking like a top notch job so far.
that crack is nasty, best get that sorted, worth stripping it down just to find it i reckon.
Keep the updates rolling in.
do you have a time frame for this?
i want it done this time next year if i can really hopefully!
haven't updated it in a while been busy but here is what I've been doing ill try update it as i go along now!
battery tray cut out so there is no rust there now. i think i relocating the battery to the boot so will end up cutting out the battery support as i wont need that
Edited by RyanC
i also got my subframe now which was gd coz i could see if that crack in the chassis has done any damage as in moved the shape off the chassis a bit!
and it did :/
it went on the back tca ok but trying to bolt it to the front it just wouldnt fit :/ as in the bolt holes are about 5mm out each side :(
Edited by RyanC
take the front bumper bar off and the radiator bar and get a ratchet strap- apparently there is that much play in the front of them!!!!
What and pull the two legs into each other so it fits?
apparently thats the idea. if the two track control arm points haven't moved, thats the crucial bit. there is apparently lots of play inthe front legs with bumper bar etc off
my subframe was only 2mm out so i mounted the rear first on the TCA mounts then mounted the front afterwards, don't forget to slacken off your anti-roll bar mount that will give you lots of extra movement with the subframe,
when mounting the front passenger side put a jack between your chassis leg and subframe to move it, you might just get it but 5mm is alot of movement especially if you've got a stage 3 frame as they are alot more robust than the stage 2 and don't move an awful lot. i only just moved mine enough to get the bolts in.
hope this helps
josh
Right sweet thanks alot for the help guys ill give it a go!
