Ryan's Tornado Red G40
Frame now fitted I got a big g-clamp an it moved the legs in they move very easy! So now I can get it welded by that crack in gonna the it strengthened across the legs and also get the gearbox mount stitch welded.
here is the subby fitted :)
BE096FB8-4027-4ABF-8291-CFCBD835AE02-204
Edited by RyanC
  • Replies 276
  • Views 42.5k
  • Few extra shots I took today. Got all the suspension tightened up today aswell then got my wheels on New genuine centre caps from Germany! Found a bag in with the mountain of polo part
  • so much new and shiny
  • Lifted the engine in with old hooks as I didn't want to damage my nice shiny re-zinced ones also fitted my dipstick that I also got zinc plated ha. Powder coated water pipe fitted, and yes all new
engine is now in bits! found so dodgey things:/
firstly i found that the camshaft 3and 4 jernal caps were loose like i mean i didn't even have to put a rachtet on it i just undid them with my finger!
also the casing covering the oil pump chain only had 4 bolts in when there are ment to be 8!
took the pistons out they all look ok a few marks on the skirt of the piston. but it had overheated before i got it
then i had a look at the bores:/
cylinder 4 had a chip in the bore right at the top just above were the compression ring would sit at TDC
and cylinder 2 half of the bore low down has signs corrosion I'm guess the headgasket went at some point and they didn't change it for a little while so it was left sitting around with water in the cylinder so it could eat away at the bore :/
here is a pic:
so I'm gonna have to get it rebored!
so i need to get oversized pistons dose anyone now were i can get them from there is only one size they can rebore it to isn't there with is 1341cc i don't no tbo but if someone could give me some help on this as I've put a post up about forged pistons and they are too much for me to afford so can u get oversized normal pistons. also do anyone know a good place that can rebore as i don't really no any good ones atm hope someone can help!
Edited by RyanC
Looks like you've got a good project, cannot wait to take mine apart and sort it out! Going to be keeping an eye on this one :)
thanks mate nice to see that someone is interested looking forward to seeing urs :)
taking the valves out today borrowed and valve spring compressor off my mate for the day
ill get some more pics of what i have done later on tonight!
Cheers! how did you find fitting the subby? really want one for mine!
can get oversized pistons from 75.5mm to 77mm.
or you could have your block sleaved on the sh1t bores?
some of the oil pump casing bolt holes can actually be for the pointer/dowels/cover
when u mean oversized pistons r they cast or forged I'm looking at going 77mm wossner forged pistons and just making it a 1341cc!
didnt no u could get them sleeved what do u think i should do? just get 77mm forged?
valves now out so both block and head are bare now
block on my stand i got off ebay.
644A3E4A-12FE-4602-9981-73C413AD7972-463
730A2B1B-A8AA-4ACC-9515-A5B2BB4E0642-463
all the engine parts in boxes in order i put some clean oil over the crank and cams then wrapped them in cling film stop them from rusting
E3201F4A-9D09-4425-BD37-63A9A11DCB50-463
i got the new ns door on as the other one was way too rusty
old
new few car park dents but that can be sorted
F98A8677-E84E-43ED-9700-6C77C6369798-463
i will take the windows and seals out tomoz
dose anyone no the best way the take paint off back the bare metal? as I've try lots of ways but still i look at all other peoples builds and they to large areas all bare and neatly done
here it is atm
F66AD8DB-5B7B-4CD0-8915-213D3D048F13-204
Edited by RyanC
once i do the chassis right and u file off the little metal bit on the back of the tca chassis mount it fit easy nice fit really tight on all corners
get one! :)
Just for for wossner 77mm forged pistons! thats what I will be getting too.
Yeah will hopefully get a subby over christmas! :)
Good work mate!
r u running g lader?
looking good ryan.
will it be ready for next year polo show??
looking good ryan.
Humm yeah maybe haha
Nope, Eaton atm. Soon to be turbo'd when I get some cash together to start rebuilding it! :)
sweeeet!!
Looks really nice this mate, nice to see another well looked after G!
depends if you want to freshen up or get more power out of it?
looking good ryan :thumbsup:
both :)
Edited by RyanC
got the car welded up this week found another crack in the same chassis leg :( the crack was that bad the leg wasnt actually connected :( the only thing holding that part of the car on was the inner wing :o
so i was lucky that i decided to get the chassis streangthed because i wouldn't of found it as it was under all the under seal
So the ends of the cracks were drilled out to stop them spreading anymore, then welded and plated the first crack that I found ages ago then put two webs on each side chassis leg to bulk head.
D0DFDEDE-CAF9-4173-8884-1D5898FABE9B-463
BE1E0A7A-5A2B-40F5-8875-6F75BBDB2F60-463
EA3420EB-695C-4080-977C-6E280DCBBEFE-463
battery tray also welded up, bit messy in there will sort that out, battery is going in the boot so the battery support wasnt needed
31AD26E9-BF09-4054-8BFF-0B14877F3F03-463
and the gearbox mount :)
a156c7ea-c50d-4e74-bf53-17bac2ba8e0b_zps
all that cost me £50 :) i can weld my self but i havnt welded in ages. the guy that did this builds roll cages so i knew that it would be strong if he did it!
when i took the subframe off the legs didnt move one bit :) so webbing the legs has help hold it in place alot better as well:)
didnt get time to get pics befor the seam sealer went on sorry.
Edited by RyanC
  • 5 months later...
updates!
coming this weekend haven't had time lately
my photo bucket account has messed up :/ so need to sort that out then will update what i've done.
