Ryan's Tornado Red G40
i welded the strut brace together today and it fits like a glove :)
B7428ADD-8B84-4563-A477-750595D5A67D-903
60AE0EA7-3DDB-48EA-9DCE-75070623CBD4-903
3B799603-AF48-4ADC-97A0-D6EDFEE3A2F3-903
I've now done two coats of primer and the ill do top coat in about to hours :)
  • Replies 276
  • Views 42.5k
  • Few extra shots I took today. Got all the suspension tightened up today aswell then got my wheels on New genuine centre caps from Germany! Found a bag in with the mountain of polo part
  • so much new and shiny
  • Lifted the engine in with old hooks as I didn't want to damage my nice shiny re-zinced ones also fitted my dipstick that I also got zinc plated ha. Powder coated water pipe fitted, and yes all new
With the battery tray, coud'nt you weld the bolts to the underside of the tray?? that way the battery would sit fully into it :-)
i could try but they are hard to get on with a welder and one of them is inside the chassis leg!
Not the nuts, weld the heads of the bolts to the underside of the tray
The tray is made out of alli
Ok then, back to plan A
some pics of my strut brace now painted
etch primed
I've painted it satin back was gonna get it powder coated with some of my other bit but just thought id just paint it now as its nice new clean metal
found some vw snowflake alloys got them cheap and not in bad condition will be power coated in a different single colour:)
also got some g60 greens off stinkypete
and a set of core plugs for the block
parts list is getting there now still need to get my gaz coilovers but i need to work out the spring rates and dont really need them until the respray is done.
have also cleaned up the steering rack as it was horrid and its now a rolling shell again, things i need to do before respray:
.drill hole for front strut brace
.prep surface rust areas
.prep and under seal the underside and wheel arches and spray black
.make my our pipe for the one that alway rots off behind the osr door card (for the pipe that prevents airlocks in the tank when its full)
I'm sure there are a few more, but cant remember of the top of my head but will try to get as much as i can of that list done over the long weekend!
have a few more thing coming thro the post soon like poly engine mounts and some febi bits off peteg40
also i have a few places in mind for where I'm getting my parts powder coated but if anyone can recommend someone good near basingstoke would be much appreciated :)
Edited by RyanC
Wow this is awesome! Nice garage too!
is exactly what i want to do to my g40, just dont have a garage to do it :(
nice fabricating skills too mate :)
taylor
thanks man i just need to start getting on with it now, instead of buying bits that i don't need atm haha
  • 1 year later...
I'm not very good at updating this... But I will try sort it out, but this has now happened :)
8DBC3796-37FE-4EA2-A7F5-B825760BC740_zps
Edited by RyanC
Update on whats been done so far..
My daily bready got hit by a lorry on the way to work so i had to sort that out witch slowed things down for a long time, i ended up breaking that as the shell was dead and ended up buying a 9n3 1.4 d for getting me to work and save money on fuel to put more into the g40 :)
alot has been done to the car sorry my updates have be none existent i will try update as much as i can from now on :/
i have now decided that I'm am going turbo and lots of bits have been bought in the last year here is a list of some of the good bits:)
31mm, larger exhaust valves
7E8B15F5-6AE7-4A5E-A6C1-F7D38E8FD7DD_zps
cat cams vernier pulley
D16E3878-1F95-4532-A999-999B2BA20C02_zps
schrick turbo cam
rothe motorsport turbo mani
KO3 turbo
forge actuator
cg motorsport clutch stage 2
5C8F9C6B-4753-4EC0-A255-20365D5637CD_zps
alli rad
8A6BD1E1-28B8-4FFD-A65D-569C424982E2_zps
pec rods and 77mm wossner pistons
95200D6F-3A07-4A51-B6CF-F45229557B3A_zps
97F71927-5FAA-4523-BFE5-57979391BA24_zps
gearbox rebuild kit all new bearing and seals for when i fit the LSD
581AEDD6-3AD1-41CB-AEBB-876A732CAF1D_zps
PPP exhaust system
0F3E8193-7125-42D7-9135-E8911CA391AB_zps
ford rs turbo front seats
3E7C2AE7-463A-410B-BB25-1C4ED26D7587_zps
max rpm ajustable top mounts.
D5B566E7-F548-4FF8-AFA0-A3FA5AF5BA9C_zps
i have nearly everything now to put the car together witch is good will get most pics as I'm putting stuff back on :)
i will update bit by bit so its not one long post.
Alot more to come :)
Edited by RyanC
so before the car got resprayed there was alot of body prep to get done thanks to Taylor for his help with it!!
so i stitch welded the hole engine bay and the rear turrets witch made a huge difference to the area around the top part of the bulkhead.
421CCDF5-A4A8-4F9C-AE7E-E9C99554F100_zps
DB9E9BA6-EE2F-4D9F-9AEF-A46388C844B5_zps
566A733F-964F-4875-9C00-A07644A373BE_zps
7AF34A20-5396-4460-B4D0-9E4CD068BE40_zps
4B31A594-3E20-437F-9AD1-0E6C79A2E9D8_zps
63D7728C-1F59-4B02-A871-B2304099E3D3_zps
57A12F2F-B17E-4B31-B1CA-1E57AF6FF7F4_zps
this is a pic before i seal sealed the welds
i aslo did the vw repair for the inner arches to streathen the chassis legs as one was cracked.
3133C161-DEF1-4781-B922-DB6515C39FE3_zps
F33C2A62-BB66-4F02-B249-49112DBA0500_zps
aslo found one small hole in the floor so i cut all the rust out and welded a plate in.
503ADD9B-9D17-44DD-9970-26DE97C367DC_zps
972D0D96-8053-4225-90CA-C4A9E5D0F182_zps
all the weld sealed, all rust patches under the car and inner arches were cleaned back to bare metal then coats of POR 15 then re sealed then the hole under side stope chipped including the lower sill and inner arches
53250A1C-5E95-4218-A4FE-8B40B183CE55_zps
78C2AC9F-FFB9-4F3C-949A-F01EA681C18F_zps
E3DDB00D-C2A6-4108-AD7A-4CBF304E8011_zps
0A5780E8-6A7D-4D01-8E11-2DBD323FEB52_zps
EF3F92B0-23B5-4A66-8285-D9BFAA7FC561_zps
78F8F633-3AB2-4E8D-9D28-EFCDBC163DD4_zps
CD7C5644-4E06-4382-BF60-2A1DC5D0B3E4_zps
21A7D0A2-624E-4C56-953D-EA24270930DE_zps
also cleaned and resealed the bottom or the doors.
1CACDB72-7B12-4188-9BB0-3B3FB58F8F2B_zps
battery tray seals and stone chipped
1A5C2178-C9B0-43D3-9575-E221F4016814_zps
under the boot floor with a new rear exhaust hanger :)
BF8DC148-305F-47E3-A2A5-C9DD53AB033A_zps
Edited by RyanC
After all the prep was done it was off for the respray :)
EA7E5FB6-42B7-4EA1-A8AD-BD088949D7FE_zps
1B0F9FF6-9112-4CF9-AE2C-871A5AF7CBCA_zps
04DF2D3C-7F76-48E3-BFC7-58A288D469C0_zps
Edited by RyanC
Great project.
Loving the work thats going into this, everything'll be brand new when it's done!
Where did you get your gearbox rebuild kit?
thanks guys! gearbox bearing and seal kit is off ebay mate, skf and timken bearings and gen seals :)
so after quite a long wait i got my shell back from the body shop in the time it was at the body shop my daily mk2 bready got hit up the back by a lorry witch wrote it off :( so that stoped work for a bit, i now have a 9n3 1.4 tdi and a daily so all my spare money is going on my g40 :)
Here are some pics of it getting sprayed, full respray including in the boot as well all car park dents removed.
E27342E1-E7E5-4D61-9BDE-34A558F75B60_zps
D42486C9-7DE5-4B3A-A96E-F19A18C1C21F_zps
D3960D49-8CE1-4BDC-8CE0-725678B57F04_zps
D8A87195-2009-48FB-A645-8F8F74AE12E0_zps
A2BEB5B9-BCD4-4FE8-9859-AB5EB8BA1696_zps
9C59F04A-5ADB-4BB5-A6BA-C7778A8F15C4_zps
315EA0B0-C990-42EB-9E97-8BACEF16E603_zps
garage tidied ready for it to come back ;)
707DBD55-8FC1-4B2C-87AE-ADD8B6F26B33_zps
then collected my shell got it home back on axle stands :)
9F5C6B13-5B88-4804-B8D6-87727644184E_zps
325C2D51-C302-4E37-BC8E-70603D974A96_zps
6267775A-8BB6-451E-B70B-29D23C4ED208_zps
6168883E-1B84-402B-8AFA-96E5291C4007_zps
re stone chipped the inner arches and a few bit here and there that i missed
0B616B1E-6926-4601-B2DD-96922C6E8976_zps
also got some really expensive cavity wax to use with my gun with a strew attachment and waxed all the cavity's, like chassis legs in the sills everywhere lol
rear legs
73521313-8A39-42DD-B38E-8A081693D9F2_zps
Edited by RyanC
had a long chat with a machine shop about my engine and mostly about knife edging on the crank
and i ended up getting rid of all the casting marks on the webs and smoothing off the corners to make it more aerodynamic ;)
and then the will knife edge balance it on he sides if you get me, so they will knife the sides until it is fully balanced
before
8A3634BE-269C-4405-B748-A25284F95093_zps
after!!
D445C541-2BE3-4E13-85C7-7D1DF3BF6251_zps
3EBB228B-BA57-4190-8423-0A13F5922ABA_zps
then got all my engine bits ready to take to the machine shop.
726F2D75-C8A3-4A65-AEF5-80EAC35664C3_zps
list of stuff that I'm getting done:
Crank:
balance with fly, clutch plate and pulleys
knife edge
regrind for .25 larger bearings
Block:
reface
77mm rebored
Head:
skim
reface of exhaust seal surface as it was real bumpy
exhaust valve seat cut to 31mm for BVH
valve guides removed and full gas flow and port match off inlet and exhaust manis
not got any pics of the block work but will put some up when i rebuild it.
9C4A1DBD-6CD0-46F7-A04F-CABA3AE711DA_zps
C1F0F82F-1792-4CD9-BE0F-A1EC827E0AD2_zps
49A0A0AC-212C-43D7-8732-74BC9E2B5E0C_zps
6C8EC2DF-344A-48A1-81B2-49A09151E8C5_zps
5C9E73C5-EEF7-4F76-B951-1429DCB9D5D7_zps
A4FED1C9-D035-4F5C-B711-61A04157648C_zps
B8698669-0882-42FC-9770-67627AC6369B_zps
7CCDA043-D801-4942-9A3F-EE01D13F16A5_zps
sorry about all the pics :P
a lot more updated still to come trying to catch up then ill update as i go along :)
here are the balance figures before and after.
crank before, way out ha
E6A5FA09-D535-4B56-A823-F18C94A1791B_zps
and after, all knife edged and reground :)
895003D5-6BFF-43CB-8548-119AAA2E6EE5_zps
The flywheel is done on it own after too.
Considering this is the lightened and balanced fly when i got it, it was quite far out too.
before
22CC9993-AAFC-4D56-A462-085F852E77FF_zps
after
9712C99F-ECD8-4A55-BD0E-1F004FEF216F_zps
Sweet build thread, looking really good!
More updates
few more things i found that i forgot i had :P
boot and b- pillar decals and heko wind deflectors
4B3A2F01-F0F0-4A40-99C2-D9612AE40FA8-463
magnacore kv85 ht leads
B555F373-F3D6-4807-9816-576B1E8C6B16_zps
metal head gasket, block and head sealing kit
129497DD-BE0C-498C-8188-6979578B82FA_zps
poly rear axle bushes and engine mounts and some new febi drive flanges
CD3F50A6-2BC9-49D7-BAC5-D6433995C54B_zps
sfs coolant hoses
5DEB393F-8C8D-4953-8FA5-A93366ADF100_zps
With my TCA's on a g40 they are rose jointed on the inner as some of you know, so i have some g40 tca's but the outer ball joints are worn and have play, it is nearly impossible to get hold of a new set. and if you find some they don't go cheap.
So i had a good idea!
looking at the rose joints they looked like they would press out as a hole peace, so i pressed them out of the worn tca's
so i got a standard tca and pressed the bush out to compare the inner part of the standard tca the g40 one
so as you can see the standard one has a lot smaller hole and is tapered inwards so i bought two need good quality standard tca's
sent them to my local machine shop and ask the to bore out the inner tca bush hole to a press fit to the rose joints
and then just pressed the g40 rose joints back in :) job done two new g40 tca's, rose joints re-greased so they last longer and refitted the dust covers just need to fit the solid nylon outer bushes
got my boot back so fitted the boot strut brackets after cleaning them up and painting them was gonna get them powder coated but wanted to get the boot on and working
BAD03F58-7B6C-4522-A60F-1EF7E2E305F8_zps
also cleaned up the struts and sealed the hinges to the body with proper body sealer
DBD89ED2-A92D-4CEF-A258-84881F36A71E_zps
also fitted my aerial got rid of the g40 one and fitted and 6n2 aerial with a better type of amplifer so should get a good signal also runs down a single wire instead of two wires
0D210106-2205-4DCA-9119-C14DCDADC424_zps
then fitted the boot wiring after checking the wires and re-wrapping it with proper fabric loom tape
732B7793-FCCC-497D-83E2-55566401E82E_zps
also fitted fabric waterproof tape the boot aperture and door apertures like they do from factory (just helps stop water getting between the gaps) before fitting the lining and aperture seals
16FADDE4-4B87-4640-9E53-22DC24A995ED_zps
Edited by RyanC
