Ryan's Tornado Red G40
so now the boot and aerial are fitted now time to fit the headlining...
what a load of fun that was ha
so obviously i couldn't fit the old skanky one
EDA68086-D968-49D2-B262-C3E3D5D9F167-141
it was all flakey at the back so i went to a car upholster and got one made well stitched together so that the rods could be fitted, they supplied the vinyl. Its not the same but its all black with a patten that looks like the inside of a areo bar lol looks quite nice tbo, they also covered the crappy inner b-pillar trims that crack in leather which looks sweet! and then fitted the fabric the the sunroof panel.
have'nt got any pic before i fitted it.
But the vinyl they stitched came as just a rectangular bit of fabric so i had to cut it to shape :/. So i put the old one on top and cut it to 1cm of the old one including the sunroof hole.
They suppled me the proper glue to stick it up with so i was all good it was basically just evo-stick contact adhesive.
so stuck the sound deadening back up and put the drain tubes in
5397798E-4F4C-4D7C-B016-C38586F51A00_zps
then starting at the sunroof first started to fit the lining, then did the front screen working to the back finishing with the a,b and c pillar parts it was a very long job to do because i had to cut it as i was sticking it to make sure i didn't cut it too short also making sure it was tensioned right with no creases of pulled marks,i was very much a perfectionist when it came to this but i really happy with how it turn out no marks or creases at all! There was a lot of taking off and re-sticking to get it looking right!
also fitted the rear view mirror, sun visors, light and grab handles to make sure it looked right.
B58E993A-BA16-4629-97D8-24F0C9A7C43E_zps
0491954E-F205-4DC6-9115-23FCF8B178AB_zps
04497D8F-DC71-4E56-889E-AC4EEB0E75BB_zps
56ADFE7F-D79E-4808-9DEE-10849ABE5287_zps
5C1B71A9-59BF-4313-8622-93219C75B3EF_zps
D936DADA-932B-4E9C-8B46-87A802610A04_zps
you cant really see the b-pillar trims but its is a good thing to do if you want them looking new again
fishing off putting the aperture seals on, got a new rear boot seal that wasn't cheap ha
Edited by RyanC
  • 3 months later...
  • Replies 276
  • Views 42.3k
  • Few extra shots I took today. Got all the suspension tightened up today aswell then got my wheels on New genuine centre caps from Germany! Found a bag in with the mountain of polo part
  • so much new and shiny
  • Lifted the engine in with old hooks as I didn't want to damage my nice shiny re-zinced ones also fitted my dipstick that I also got zinc plated ha. Powder coated water pipe fitted, and yes all new
few updates,
next i then refitted the sunroof, took me a little while to remember how it all went together after completely striping it down a few years ago lol
used proper sunroof grease BMW stuff really good stiff too
0FF769FC-C41A-48DA-B3F6-EA50E07E5180_zps
A8BD2671-4820-45AA-A477-0E185E918EB6_zps
all back together with the new lining panel fitted, after very carefully feeding it into the roof without scratching the paint, all fitted sweet
new gen outer seal fitting which was like £60 :o
18F3F9A2-4659-44E9-8AAF-E85D52AD85DF_zps
18A64021-CB75-4417-83E8-49D79B5F80AC_zps
more updates to come
nicely done! I've made 2 roof linings now, a very satisfying job!
The loop for the rods should be cut at a angle so the rear window rubber look perfect aswell! incase u didnt do so. I'm sure you did tho :)
keep it up!
cheers man! yeah i did, windows are all in now will update properly in the next week or so :)
  • 4 months later...
I'm never going to be very good at updating this haha. There are a few things I've missed as I get stuck into a job and forget to take pictures but will try and sort some and update to where I am now.
so fitted the windows next
Rear window bonded back on
33D0C95A-E4AE-4A69-B806-83AF362D09E7_zps
56BA80BF-C5CF-49D7-9ED5-C998B13EB309_zps
And then the side windows and windscreen
4E147D53-BFE9-4403-ACC7-C0BA3EBEB5EE_zps
32DE969F-7EEE-4D00-ADB0-B603E10349B8_zps
Rear badges back on
17EA5150-DF7E-46DF-97CC-AAA42437D901_zps
Edited by RyanC
Got tones of brackets and parts powder coated:
Rear beam and mounts
Subframe
Arb mount
Wiper arms and linkage
Gear linkage parts
Engine mounts
You get the idea pretty much everything I could think of has been blasted and powder coated
Will put pics up as I fit them
Also got some parts re-zinc plated like:
engine hooks
Steering rack clamps
Bonnet catch
Door striker pins
Ecu mount
Etc etc haha
A851B15E-2146-4E43-A708-E6673EB69F7B_zps
New rear boot seal and re-zinced stricker pin
1D78FC8F-EA4B-475A-9E98-0C577EC7BC2C_zps
Door stricker pins! Love all the zinced bits!
0A085C88-B6A6-4072-8C6A-A12832DDC94A_zps
Edited by RyanC
As a lot of you know, the pedal boxes are common to crack so I beefed mine up a bit with gussets, plates and stitch welds to try prevent it from happening
2B775B1D-315A-4F4A-9BAD-1708BE73DA9D_zps
Then got it powder coated
68ACE2C6-FF3B-4084-A107-FE3BD40A0352_zps
At the bottom of the first pic I've made two plates to sandwich between the mounting bolts and the pedal box to stop it from twisting.
Fitted it without and with them fitted and it makes a hell of a difference don't move one bit with them fitted but without it try's to twist when applying the clutch.
Steering column fitted and pedal box back in with powder coated pedals and new pedal rubbers and pivots cleaned and regressed
DB308E34-4C67-481E-9612-F87B3579CED8_zps
6DFC3E32-954E-4592-994D-0E73324AF150_zps
DA47930A-82BC-4D49-99C9-3A060F246017_zps
Edited by RyanC
Cleaned up the gearbox ready to be stripped to fit the LSD and new bearings!
Before
3503E260-15C9-4973-89E5-04A0F1719457-463
After
5A4A2F14-5946-4077-889B-23DF5D72E1D6_zps
Then cleaned my brake fluid reservoir, striped the paint off the brake servo and etch primed it then put 4 coats of hammerite satin black on it.
Cleaned and regressed the steering rack then primed and painted with expensive Ali high temp paint.
722FE1C7-13A1-46BC-B056-E4FF9CB70DEB_zps
New steering gators fitted, then refitted the rack with my re-zinced brackets, servo fitted with new 22mm master cylinder
F2B78080-3E68-4194-AE07-2337EE496233_zps
9CA8959E-F158-4971-868D-21CFF9B76E53_zps
146AD390-A021-4F6A-8BF7-14AD68ACCD23_zps
Edited by RyanC
Absolutly stunning. A hell of a lot of effort you've gone to and by the looks of things it will be worth it.
Thanks dude! Yeah can't wait to get it finished!!
Polos dont get much nicer than Tornado Red G40s.
G40 KCK is a nice example.
Then it was time to do the brake lines that I wasn't looking forward to doing but actually was quite good fun....
Ordered loads of copper pipe and zinc plated unions, also bought heat shrink so I could put it on the pipes were it could rub or vibrate.
So got started..
I have decided to run all 4 outlets from the master cylinder instead of blanking the front one like a few people do, as standard g40 master cylinders only has 3 outlets with a t-peace to the rear line.
Had to make sure I plumbed in the lines right so they would work angled if on half of the master cylinder failed.
61D10525-F988-48C7-965F-D8F7DAF2D282_zps
FF72F4A9-4BDC-4391-89BD-2AC8130387B3_zps
85FDCC08-A373-4D6B-9A4C-BC3BC820D415_zps
C3016DF2-DC35-4613-BEA1-FB53B85023E6_zps
E54FEC81-053F-41E8-83BF-8740701E36DD_zps
8E8E8E51-7D5E-4A06-9992-0BD082616B74_zps
Rear lines in as well. New load compensating valve fitted with powder coated bracket.
388D22A6-A225-4A6D-9F80-EC143945EF16_zps
Edited by RyanC
The joys of fitting brake pipes in an empty engine bay! Hah ha.
Me and my OCD then kicked in as I wasn't happy with them, as copper discolours quickly and they started the go really dull and after time will go green, which for most people they wouldn't care but after all the effort I put in I wanted it to be right!
So I pulled them all out again haha
B96C2388-F0EF-45FA-9682-E9ECC6C9B4D7_zps
So if anyone is after some new copper lines that will fit straight in feel free to PM me!
So did some research and ordered some copper/nickle plated lines (Kunifer) that stay nice and shiny and won't lose colour and obviously will no corrode being copper. Also bought some brass unions instead of metal zinc plated ones as after time zinc ones will rust!
F96DD7C0-5CE6-4DA6-8991-4367557A8192_zps
So off I went angin! Was much happier with the outcome this time!!
0CDAEB0A-615B-4182-BE06-E4E4B80814DC_zps
E30A6481-D52E-4824-9D5C-ACD4A554E27A_zps
A1721702-E5A9-4B64-806E-D53239020B61_zps
54729E25-F490-40BC-A967-EE6532BDCE75_zps
91769F85-1F13-4518-8D9D-8537F2848E50_zps
C7469B97-7E89-4F25-8687-76BAEEB16D4E_zps
47980F5B-5F1E-43A4-B220-82D8EE980379_zps
Very nice, I am hoping to get hold of a Tornado red G shell in the near future, this is excellent motivation to do it properly
Here is a better photo of the new headlining that I fitted the more I look at it the more better it gets! So happy the way it turned out, not sagging, looks very OEM.
4A75539C-5179-4B9A-AE46-6C01CB753CBB_zps
Next thing I wanted to do was get the engine and box rebuilt and put it in so I could then just start working round that really.
So rebored block back on the stand! Took the core plugs out to replace with new ones and removed all rust and crap as much as I possibly could, took a while but I got there with various wire wheels in a drill.
Block after.
8091DD0C-40FC-47CA-9AB6-0B570DCF9CBB_zps
F684B985-71B1-40FF-B0EC-670FEA963F59_zps
EA2522C6-B8FB-4B9C-8B6F-8FD5A4BA5382_zps
I then got the gunk and pressure washer out and covered the thing in gunk and let it soak all down the oil and coolant channels etc.
Spent a long time cleaning it all out blasting the pressure washer down all the channels to make sure all the crap was removed.
I'm sure they were quite clean anyway but I wanted to make sure.
49D01168-6757-4A09-8836-8AB74BA4E0AC_zps
Didn't want all the bores rusting up so run the compressor up and got the air gun on it and dried it all out.
7A19E90C-1E72-4845-8DC8-313A5EF56DE5_zps
666CB7EB-4E2B-4C93-92CA-D2896DE41B8C_zps
117CF961-97D7-4811-A871-29536AC648AF_zps
3F8B8F37-88E9-4757-B3CC-8CC411C70140_zps
Fitted the new core plugs used a small amount of sealant around the edge and tapped them in the a relevant socket.
C4A11BFC-438B-40AC-9D3A-C6579A1090E4_zps
9834CC46-0213-4579-8BFF-6201083091DB_zps
Then etched the block surface with POR15 metal ready, really works well! Masked it up and put it in the spare room to paint it as it needed to dry at a warmer temp over night. I got black POR15 engine enamel, stupidly expensive but had best reviews and i've use POR15 on the bay and was very happy with it! Still have a hole tin left as it covers very well!
6E02C232-36EB-4F83-BECC-7F70FF53D17A_zps
Done two coats second after 24 hours brush marks settled well can't see them at all!
A552B4EB-4747-4FEC-9F5E-4DC6A789F5A9_zps
Put the block aside and started on the gearbox. So stripped it down!
8A9B4D2D-3CB2-42E8-B75F-0C509612F3F7_zps
171EE480-E236-4802-A2A9-928107A1252E_zps
Failed a bit at getting photos of the work I did on the box but most of it was done before work so was under a bit of pressure to get what I wanted done before work started.
Used all sorts of pullers etc to get all the old bearings off the shafts and races out the casing as some need blind pullers!
But I got there in the end was a bit of a nightmare setting the pre-load as I had to do all the shafts and diff. Had to put new races in without fitted washers and measure with DTI then remove them without damaging anything to fit the new washers. I now have a wide selection of spare washers ha.
Got the crown wheel off the old diff and pressed out the press fit studs. Removed one bearing to get the speedo gear off.
Dug out the LSD and pressed in the studs
DB1EF4D9-D3FA-4B7F-BBCC-3601AA28A892_zps
Then fitted the crown wheel, plates and torqued up the nuts with a dab of thread lock. Speedo gear on and new bearings fitted
All ready to fit back in!
79045C2D-8AE7-4127-9145-37B5E5223CB9_zps
So all new bearings fitted, pre-load set and washers fitted, inspected all the gears etc and is all spot on! No chipped gears and all one use bolts ordered from vag ready to rebuild.
Go on and painted all external components degreased and wire wheeled all the crap of the casing like I did with the block.
5D4E56DE-0270-42C8-A734-ED1D0718CEDB_zps
A03F353A-94C1-4783-9E3D-0E40CEF360D1_zps
714D092A-AE14-4356-9610-4C8BE75284E2_zps
Painted the casing first before rebuilding it. The split it again and starting building it back up.
7A69AEA1-F38B-45F0-8E7A-655CFC3AD2F1_zps
75D30D3D-F247-4C0D-A996-FCF5A0C089A6_zps
4628EC90-5D5F-4414-BFFD-AF5DD1CEA871_zps
E752CE71-C63E-4FCE-AD9B-2E869980623A_zps
765A4600-962E-4EAD-BBAC-9F837CD316EE_zps
Where a few fiddly bits but nothing to hard. Bearings coated in oil and top casing back on. Used the proper sealant vag stuff, all casing bolts painted and torqued up.
F33E4D4C-2DF2-4057-90D8-C8936E2982B6_zps
flipped it over and started putting 5th gear back on.
E11652B1-0797-409B-9704-A383D160E33B_zps
All new radial seals and 5th gear case seal
38640AB6-C7C3-4E08-BFFD-E12AA6C4D089_zps
Powder coated 5th gear cover and drive flanges back on.
DF69E2A5-6590-484F-8909-88FC9C8A191E_zps
Done!
52F3CDAD-F147-4AF7-8E2C-7510C2E52F7D_zps
Filled it up with oil, checked I could get all the gears, fitted powder coated mount and put it to one side!
CD1445AA-33E9-4B9A-A8DC-71E66C803579_zps
Engine rebuild time!!
New +0.25 main bearings fitted to suit reground crank.
4D6AA609-67F6-4732-B589-BC450CE95809_zps
Thrust washers fitted and engine assembly grease over bearings and journals
77B2830D-9243-4855-80D8-6A88833D1B33_zps
Knife edged crack fully balanced and ready to fit. A lot lighter now
2CD148CD-958E-4D64-ADF5-DD7EE0D3B70F_zps
New bearing cap bolts all torqued up
73005B28-A784-48B9-9890-8AB29195AAA5_zps
Fitted the rods to the pistons and fitted rings and clocked them to the right position, checked the gaps before I fitted them.
F1DB65E5-D66C-4495-AF05-FD01A28EE48B_zps
Also fitted an additional dowel for the crack pulley
01A58E91-628F-4704-9065-F7D21765BC10_zps
Pistons fitted, new +0.25 big end bearings. ARP rod threads greased and torqued. Then checked crack end float etc
BC8F57CF-BF2D-4C00-9576-829A963ED204_zps
E5CC3144-A3AD-4882-B255-3353C3AA7DAD_zps
3C76C659-87B3-4CC0-98A8-41CDA9A5CA3C_zps
Awesome work fella!
What an update. This is a meticulous build. Kudos.
Cheers guys! Stuck in hospital at the moment grr, long story but will try and update to where I am now by the end of the week. Work has stopped on the car due to me being signed off work and not aloud lot lift anything until august :( So am on the computer ordering car parts ha :)
Looks amazing, keep up the work
This is going to be such a clean looking G40 once it is finished. Keep up the good work.
