Ryan's Tornado Red G40
Cheers man!
  • Replies 276
  • Views 42.5k
  • Few extra shots I took today. Got all the suspension tightened up today aswell then got my wheels on New genuine centre caps from Germany! Found a bag in with the mountain of polo part
  • so much new and shiny
  • Lifted the engine in with old hooks as I didn't want to damage my nice shiny re-zinced ones also fitted my dipstick that I also got zinc plated ha. Powder coated water pipe fitted, and yes all new
Those seats are lovely. Are they Ford recaros?
Yeah Ford seats mate, took me ages to find a mint set with that patten.
Would have liked to have seen lighter coloured wheels, but I'l reserve judgement until they are on. How long until its finished?
I was a bit worried they might look a bit dark, but they ant as bad as in the picture. I think they will look sweet! I was going for the same colour as the seats and they pretty much are so fingers crossed. Not a fan of silver wheels on a red car. Depending on my recovery really, will deffo be ready for next polo social.
Edited by RyanC
Finally able to get back on with it now! Been nearly 3 months since I last did something on it :(
Anyway today I pressed my new FAG front wheel bearings and Febi drive flanges into my coil overs
AD1D03A9-E97C-4C0F-8F1B-2A4432741142_zps
A527E191-89F7-4AA7-86B3-4407484183DC_zps
I got a new patten fuel tank ages ago that I painted and went to fit before I went into hospital but I wasn't happy with the fit of it, was all wrong, it fits and would work but just not a nice fit, with some bending of the filler neck it would fit fine. Come across a genuine tank for sale that was pretty new with very little surface rust so I bought that!
Spent most of today cleaning it up and using a wire wheel to get rid of the surface rust
Then coated it in zinc primer
F495ABF4-0087-43A9-BC35-FA26D43C0F4C_zps
Tomorrow I'm gonna seam seal around the edges and around the bottom of the filler neck then coat it with Hammerite. I would of had it powder coated if it was new but it had fuel in it so not a good idea. I will then stone chip the areas exposed to try stop it from rusting out in the first few years.
Edited by RyanC
So today I seam sealed around the filler neck and seams of the tank
3AB7416A-0B1D-412D-A7A1-14A2D64616B9_zps
D89822C5-77DD-4E88-9508-AF47BB147B8C_zps
Then coated it in hammerite, when thats dry I will stone chip the exposed areas.
BB85E8A3-7B6F-4939-A6BD-A33C9B406183_zps
Hopefully It will last for a far amount of time now....
Removed steering arm ball joint and inner rose joint dust covers cleaned and re-greased them
A64CF4C7-52F4-4B3C-9FD6-14C07F14E130_zps
O/S non adjustable steering arm painted and dust cover back on!
2CE2AD77-B0FA-4519-805C-D7729368A1D7_zps
Wire wheeled the rust off the steering arm fixings and adjustable side joints and rear axle mount bolts ready for some paint to stop them rusting again too quickly.
C5335A14-1085-42E6-8877-24CEE833A8B7_zps
Put some grip tape on my freshly powder coated throttle pedal!
D64ACDCF-D053-4E15-8009-59475333B3D9_zps
And stuck on some new door check strap foam seals (still need to paint the door bolts)
54B2D2FB-F19F-4173-A8D4-002760E3177B_zps
Edited by RyanC
absolutely awesome mate.
brilliant work... totally reminds me of putting mine back together!!
Cheers guys!
Got the parts I cleaned up primed just need to paint them black then there done!
44FB05F9-1C30-496A-9349-C84B6191BC0F_zps
Also took my cv joints apart today
E3A90318-2D82-402E-A1C9-559EAF2A2090_zps
Messy job I hate CV grease!
Cleaned the rust of the joint housings and primed them.
811203BD-D507-45A8-9951-8ABE11E19A31_zps
Then painted them with some paint I had left over from the gearbox.
E644F3AF-F575-4042-BFFD-308846FBD988_zps
Cleaned all the crap off the joint cages and bearings, then put them back together, bit fiddly but not to bad.
A12E394F-3474-472D-9E4A-B6BD84EDBB28_zps
Also painted up the clips for the bolts ha
77299DB0-8C67-42FB-B77B-243105B622EA_zps
Tomorrow will rebuild the shafts got an uprated O/S shaft and 4 new cv boot kits as the old boots were about to split and were cracking up.
Got the shafts built back up with new boots, clips bolts and both shafts powder coated
0C640811-F4BD-4716-BF11-CCF2045F28AF_zps
83382711-A070-4A12-9F1C-C9F1773EC6F5_zps
C5317E3B-C7E6-44B2-B386-B9C3692D0B0D_zps
Also got a new old stock audi brake fluid cap as the sensor plug sits a lot lower that the polo ones so i can still use the level sensor as my strut brace is very low and fouled the polo cap.
03BC665A-B7BB-4E46-B32F-3F8FE2AE2854_zps
Finally time to fit the fuel tank! New strainer and sender seal
4284A89C-B6DF-4C31-A704-BC825FEA4056_zps
Stuck the foam to the top of the tank and fitted the sender unit.
1594EF24-A56C-43F2-882C-0FA13C0C6709_zps
Breather pipes fitted, not using a charcoal canister so cut the black pipe and fed it down the side of the tank like the mk2 tanks do.
0CB7F1DA-DE36-40EB-9799-69CB496D8DE1_zps
Fitted a treat! no issues really. Powder coated tank strap fitted. Fuel flap with stainless bolts.
191CCC1A-910E-426A-B78A-DE88851CC011_zps
FFDBB242-B511-418C-83FA-7CD655F96683_zps
D8E64B94-5F6D-4305-983F-C7B8C1209692_zps
E2EE4A55-C5AD-4445-B670-DC32903F6B12_zps
Powder coated fuel pump bracket, new rubber mounts. Also removed the old rubber fuel pipes from the hard lines and fitted new ones with crimp clips. Uprated fuel pump rated to 250bhp.
DE3D0C73-231E-4237-A0D5-73500AABE277_zps
DA8864F1-8BA6-4A95-9B91-764262B10370_zps
77806E0F-B631-4141-936E-3C9475D7BEE0_zps
Just a case of bolting things back on now! Most things have be bought now just wiring to sort out!
Now the tanks fitted I wanted to get the car rolled out to clean up the garage as it was a mess! So started bolting all the suspension on!
Decided to use standard replacement febi rear axle bushes as i don't want it being to twitchy. Powder coated rear axle, new mounting bolts.
Gaz coilovers rears springs are 10" 160ibs to start with will mess around with the damping adjustment when its on the road!
606B0CDD-15A4-4BEF-8573-EC5686702CA4_zps
Powder coated rear axle mounts fitted.
EF84A20E-08C1-495D-BEE1-FF73034467BB_zps
Axle and coilovers on (wond right up at the moment so its easy to work on and jack up) Mk2 Golf GTI stub axles for rear disc conversion and new backing plates.
I have camber shims to fit when I get the alignment done.
4F389D26-721E-425B-B829-DD5945E175D5_zps
New febi bearings and Pagid rear discs
B1EC9F40-F336-4AFD-9A6A-4A64750FCDB2_zps
Used my tool to tap in the bearing races so much easier!
96861378-FE8C-4691-A715-9A8A3E63E66E_zps
C996800A-DC25-481F-BBE6-57AC42AD2EE3_zps
Bearing packed with grease ready to fit the discs.
C5C65523-0605-4C41-8304-ED367E63F062_zps
6880612D-4523-4D06-81FE-9723F23450CA_zps
Need to rebuild my callipers yet so will just put the wheels on like that until they are done.
Steering arms all painted, boots removed greased and refitted.
CE0CC8CC-211B-470D-BEB3-581E6C3ACE23_zps
27D56695-78D8-45E5-913D-2FC06F4E65C1_zps
Drive shafts and steering arms fitted.
2E5D5CEC-A123-4C76-A868-243904AB527E_zps
28CE781A-3C80-435A-8D38-7B20AE2A7806_zps
Then fitted front struts. Springs are 7" 275ibs, need to see what its like with body roll as there is now no ARB..
7A183D1A-5256-46CF-B97C-2284A1A435B3_zps
nylon outer TCA bushes fitted to my refurbished G40 TCA's :)
52E43E6D-D317-479D-BA7C-E83C617215FA_zps
Brembo Max 256 discs on. I have new discs backing to fit but will put them on when I put the callipers on.
3D8F4822-E0C2-47EE-B6DF-4399F881AEB4_zps
Edited by RyanC
As you can see the garage is a shit hole! So I really wanted to roll it out to clean the garage!
A079DFEE-8E2F-4F98-83A2-DA5C945D7757_zps
CA110F6A-B95F-4AFC-B070-985C72E80DBF_zps
ADDFC340-EFEA-4745-AAFD-E819ABDA5A08_zps
So got the temp steels on and finally got it rolling again!
9DCC1526-160D-40BB-B76C-818D5BE2DF3F_zps
For some reason I didn't get any pics of it outside.. Ha, but I will next week. Its soooo red in the sun :D
Nice and tidy ready to get this thing finished!!
D9A3426F-D693-4ED0-B9E3-2B720D89FD17_zps
In the week at work I got a bit of time to clean and paint up the door catches wanted to get them zinc plated but they are near enough impossible to take apart.
But they look fine painted up I think. Came out quite well.
A77F2113-1B3E-4E42-A82E-D0DDBE874134_zps
Thats all I managed to do in the week due to me having my MOT assessment next week so have been practicing my routine! Had a few nice BMW's turn up for the open day at work.
3.0 CSL
01AB01E1-1AA3-4BEB-8932-8E49FF236677_zps
M1
63C0ED62-9F29-4CDF-A9B6-65D8F413AEE5_zps
Was at the British Superbikes today but yesterday after work got the rear spoiler on, clean it up and used new butyl seal tape.
1E66A9F1-A8C8-44C2-9D5D-6F09CB4BB3DA_zps
6DC65DD1-B460-41F0-BFB0-90E0BF7ACA7E_zps
Then did something I wish I never started but needed doing. Took my Ford RS turbo RECARO seats apart to sort out the bolsters, base foam as it was ripped and clean up the frames.
AEBD1C58-CF25-48C9-B35F-B2A19AF76E4D_zps
Love the seats there are soo comfy but will be spot on after they are cleaned up and sorted out!
This build makes me wanna cry :sorry:
Such good quality stuff going on, literally not a corner cut!
Little update, hoping to get quite a bit done this bank holiday weekend!
Took a trip down to hobby craft.. Got some foam sheets and felt sheets.
Used the foam on the bases, just used fabric spray adhesive to stick the split back up then wrapped them in foam, I have new stronger base sheets under the base to fit so it will stop them from sinking when sat it them.
86D1233C-AF06-4920-8288-1D2825AFBB96_zps
Then on the bolsters because of the shape I used felt sheets and did the same thing as the bases and on the underside where the frame sits inside I have put additional foam to make them more padded again. £80 for 2 new ones was not a option ha quite happy with them though to be honest they wernt really that bad!
3B1B622A-1B92-4534-99DC-A99ED067728F_zps
Then found the seat base frames were cracked... So got the welder on them, luckily I saw them I couldn't see them lasting long if I didn't.
FEE1C087-0E77-4316-8246-A421B3A84D30_zps
2B16C7FA-2F95-4F58-AB60-111A6AAA6B89_zps
They were a bit rusty aswell
FEDADFD3-9360-4F61-8424-6BF8346200BF_zps
So borrowed my mates shot blaster and cleaned them up
536C25EA-6738-43A9-8007-E4FF3D76D76E_zps
I've put a few coats of hammerite on them, none of it can be seen then they are all back together so didn't need to look to fancy just stop them from getting any worse. Will get some pics once I've built them back up!
Also rolled it out for a bit, sun went in though :(
4D66011E-F6FB-4E9A-B941-F635E7C8275C_zps
519C939C-8266-43B8-B653-0B601EFC1188_zps
Few coats of hammerite.
7AB44BA6-1F14-4B30-A0EC-2857D6816199_zps
Started rebuilding the seats wasn't no where near as bad as I thought it would be, new modified spring beds as the old ones were split and you just sunk into the seat.
39145959-A7F0-4393-8E75-BD03A3EFD5C7_zps
Base all done all held on with new hog rings and staples.
75425EBE-08BB-4816-8D80-DDFFAD13F8FC_zps
First one all done!
33902B4A-A07B-456C-9093-7947BB94D1B6_zps
Second one took half the time as I knew what to do! :)
EADBA6AD-BE62-4AC1-8C86-19E289C00342_zps
Then fitted my homemade seat bases freshly powder coated.
E6B77E4A-4302-4BA0-A800-C7A512AF780C_zps
A12DC435-8794-4DCA-998C-CCBDAC538891_zps
Stoked with how they came out, don't fall into the seat anymore and the sides have a lot better shape!
Edited by RyanC
Lovely g and stunning build. Surprised that your not going to put a stock interior back in it though.
Thanks! I do have the Stock interior that I can put in anytime I'm just not really a fan of the coulor and its all faded from the sun so it's like gone purple.. These seats hold you a lot better too compared to the standard seats.
Have you had the recaros in the car yet? They look a bit lower than the standard seats which is exactly what the seating position needs in these cars.
Yep made them so they suit me! I'm 6ft4 so need to be really low!
This was the trail fit before I took them apart
7CEC930A-9462-4E0E-A695-7E5A43624FD2_zps
They will look well nice in the car an a fine job you have done on them as well
I don't understand why VW never used recaro seats in the first place
Cheers, VW seat from that time was made by recaro just never stamped up as them all the side trims and adjustment wheels are identical to VW ones just never made them with as much padding as they did for ford!
