Ryan's Tornado Red G40
I think some golfs came with those type seat though
  • Replies 276
  • Views 42.6k
  • Few extra shots I took today. Got all the suspension tightened up today aswell then got my wheels on New genuine centre caps from Germany! Found a bag in with the mountain of polo part
  • so much new and shiny
  • Lifted the engine in with old hooks as I didn't want to damage my nice shiny re-zinced ones also fitted my dipstick that I also got zinc plated ha. Powder coated water pipe fitted, and yes all new
Few updates :)
New dizzy fitted.
E6636FDC-4ABC-4674-AB29-30A88A8C98B0_zps
studs fitted in head ready for mani!
E7E352CC-919F-48A7-A0D4-46D8FB55A099_zps
got a larger bore gasket as the standard size gasket is to small after the porting
DBB0C64A-09B6-49E0-AEA6-44A693F2FD06_zps
rothe mani on! painted it with POR15 manifold paint
629AFFE1-F2A1-4DA2-879C-D87DAD9411BE_zps
Then put the turbo on :D k03-029 turbo that I got refurbed with and uprated thrust bearing. Look brand new! 04BB9678-799D-4574-8555-9705C4FB4DB3_zps
8AC1AD2E-5D8C-4A73-B384-784D60AF9529_zps
hot side painted with same paint as manifold!
forge actuator fitted setted the preload up.
70F08B4E-F0BF-4B68-9B23-64B30698D61B_zps
8EE5FCAD-2BBF-4553-949B-951364D7EDF8_zps
aux air valve cleaned up fitted with stainless bolts new clips etc. knock sensor re-wrapped in loom tape
24EDE41E-7AA5-4422-96AC-0744781647F6_zps
door lock mechs
9BFADEB5-B7E8-48E4-9879-B7A1A8CFA96F_zps
Edited by RyanC
new powder coated brake disc backing plates with stainless bolts.
BB280981-B3A0-4D84-8752-14669504FBED_zps
striped down the wiper linkage got the bracket powder coated and painted the linkages and motor then re greased all the joints
E1498517-D983-446D-91F2-CF1728311E13_zps
then fitted it
285A40F7-6FC4-43AF-B7E3-45C7AB711341_zps
put it off for to long so got the brakes sorted
stripped the callipers down so I could get them powder coated girling 54 fronts for the 256 audi setup and mk4 golf rears
112DB333-6A9C-4491-8AD4-9D065C972AE6_zps
Back from the coaters they look mint!
7BB5EE7A-B889-4445-B481-3D4FDBCBEA8A_zps
cleaned the paint off the rear callipers where the banjo fitting seals seats.
191CA1E5-298E-44BA-84B9-AE6A9E833BE1_zps
so got cracking building the callipers all new seal kits pistons were fine just needed a clean up.
7907D09C-A27C-4EA2-B605-EA3FF7BFC35C_zps
rears more complex than fronts being handbrake callipers but not to bad really with the right type of cir-clip pliers it make it a lot easier!
D3AF9344-5ACF-438F-8E23-09105BF8D6C5_zps
4DB00B7A-3663-43AF-A8FC-B085689B4F01_zps
Done! Look good as new, used proper red grease to rebuild them makes it much easier and less mess the just using brake fluid.
8C6D373C-7222-4D11-AEDF-FE53C8A10804_zps
New bleed nipples too.
0A45B961-BCD7-4C65-8448-33CCE5781A3A_zps
51E3FC7D-AF92-4183-A67B-EDA38002952E_zps
carrier sliders cleaned and painted
2FF0C923-B6A2-4629-A089-05373CCE8458_zps
front coated carriers on, new gen lock bolts. new slider boots.
B3E39FAA-855F-463C-ADF1-D4CB7E91CA3F_zps
same with rears.
8E293856-D5D9-4AFF-8AA7-3098680B2A79_zps
expensive brake pads! but lots of good reviews, a lot of the g40 lads use the ferodo pads
CBE4A43C-2BAC-4410-B810-1D5317A2A2B2_zps
5A6B6768-0395-472E-959C-0566D59E0742_zps
84F5AC24-089A-4FFD-B49D-57444079A7E6_zps
Such a clean build, totally love it!
front callipers on, flexi hoses for the fronts are wrong sorted that and got the right ones.
2969328B-822E-4B72-8EA2-997C16E3ED90_zps
F4679843-C5B8-4E7B-BC96-B7B7343E05E4_zps
nice red ones ha
CBB3F3EA-CEC3-4889-8E2B-ADA4A133E15E_zps
rears..
5B23C412-C1AB-4338-9CA5-737A25CEC773_zps
Had to make two brake pipes to join the polo flexi hose to the mk4 flexi hose both hel brained lines too!
D6D348D2-C58A-4FC8-BD42-ED236CEF2DE7_zps
BB9042C1-91E3-468A-BD90-F02BD59213E8_zps
Handbrake nearly sorted just need to put it together and then bleed up the system!
Edited by RyanC
51044E30-AD9C-40B8-A9DD-DAB5406F1590_zps
rear strut brace I made years ago! finally fitted haha
F16C124F-685E-423F-A31A-32841422D65C_zps
Washer jets and new pipe work, need to sort out washer bottle yet so left it at that.
EDCCDF17-F50A-4E6B-8D43-035AB073775B_zps
Front sound proofing in and foot rest thing.
E5E6A839-042B-477A-900D-50640201CDE2_zps
completely stripped the heater box unit in two and cleaned it up. it was disgusting! new foam seals as well haha. I must be mad going this far into it :ninja:
E96A049A-40B7-431E-9154-25D291235664_zps
3CCF6F19-5F85-4B55-9717-8A9B1F1BADF7_zps
Same with the heater fan unit. new heater matrix and butyl sealant where the inside box and fan unit meet. sfs hoses on with new spring clamps
6E7CDD91-6CAE-4602-B2C2-7A65E412DEED_zps
A44BB970-F753-49B4-A952-418848963665_zps
0BB9FCEF-6E92-4D0E-BE8B-FB99C2471F4E_zps
A8434528-FAD5-4E88-B147-C39922824431_zps
53606C97-E10E-4B11-A83F-EC957279FCC7_zps
Edited by RyanC
Got the windows in the doors. powder coated centre rail between both windows all mk2 seals as I'm using mk2 door cards and trim.
Stripped the wing mirrors and got the arms powder coated the rebuilt them too now all fitted.
All door handles on with mk2 chrome plates, I think they look better than black plastic ones that use to be on there.
Starting to look like a car again now :)
55F29544-DB6B-4426-BB5F-5C04447A17FE_zps
17E69F7D-5933-48B8-ACED-A30F4B80911D_zps
6C84FA2B-F707-4188-839E-5FB4A8AECE18_zps
56D3BF8D-8DCB-459B-83C9-6FCF45B21E75_zps
B1728D73-CF74-441B-B773-D85EA28983AF_zps
Edited by RyanC
Ohhh very nnice!!!! :)
Thanks Mark :).
I am missing a few photos but really hard to remember to take photos then you get stuck in.
We are getting there finally. I've only owned the car 4 years :paranoid: haha. Drove the thing about 15 yards!
More to come soon!
Some stunning attention to detail and it's going to look amazing when it is finished.
This makes my own project seem so insignificant [emoji23]
Looks like I could eat my dinner off any part of this car it's that clean
Blimey.
I had no issue spending half hour with a mug of coffee reading this thread from start to finish. Inspirational stuff. Makes me want to start my car all over again to work to your standard!
By far one of the best builds I've seen for a long time, love the attention to detail! What a fantastic achievement so far...keep going!
Thanks for the comments 😊.
Few more bits done today. Heko wind deflectors fitted. I was a bit unsure about them before but seeing them on they look better than I thought!
ACD0673F-7213-40A9-95CB-E5AB174FBF1B_zps
Now the callipers are on I could get the hand brake connected up.
A8E7BFD0-0B90-447E-99B2-6935E7B2D5E5_zps
As I'm using golf rear callipers but polo cables the nipples on the end of the cables are not the right style for the lever on the calliper arm. So got hold of Pete again and he made me some stainless cable knarps so the cable would work without the chance of it pulling through the arm.
24E18851-2E3F-4443-A228-AF24CBA5F970_zps
Cable adapters fitted, I had to cut them down 15mm to get them to fit because the cable was over adjusting the handbrake but after that it works perfect :) all the cable links and brackets have been powder coated btw just so you know 😂🙈
260DF193-DB64-4CE6-B591-A5D95BF94F43_zps
9A3415B5-6BBC-4EB3-A6B0-8909CE9DC7EE_zps
Ordering some p-clips to hold the cables up because as you can see 👆 they hang low, would be ok but rather they were tucked up neatly.
Edited by RyanC
5553A070-2B6F-474D-9F61-F457489A4926_zps
59D9C9A6-028D-4FF5-9142-2A8FBE54B957_zps
E2C4F422-32F0-421C-A660-3CC1CBBB8BD8_zps
6E33FCB1-E6C1-481A-8A16-EEF7DE4AEAD9_zps
A8A95553-8B79-4212-B415-7BBDA1B82F93_zps
Found a bag in with the mountain of polo parts I have that had a full set of pretty much new genuine wheel bolts, still look gold from being plated from factory!
E0401FF2-653B-4B96-89E3-489A3F598867_zps
86BD7026-721E-4C8C-8089-1C7626746989_zps
005F9E7B-5D1D-40D9-BFC5-52731D91CA60_zps
40F47EA9-3D3D-4488-92B5-BD6AB3241211_zps
72AAD8FB-9156-4247-853C-F098A36A4310_zps
5ADD1BE9-4568-44B7-AB92-F11A1005B10A_zps
83ED3927-2070-4903-8E85-0CC0F29AD201_zps
5BC485D7-7F1B-4435-8CB8-0CDDA6289FB9_zps
DACE5236-4F46-4D6D-B959-085D320E57C1_zps
I'm happy with the colour, was a bit worried they might be to dark but I like them! Can always change them at a later date if I get bored.
Needs to go a bit lower yet. But while I'm still jacking it up etc it's better at that hight won't be a lot lower though, subframe is close enough already to the ground. I happy with the fitment too could put spacers on but I'd rather it handle well the have good fitment, sleeper ftw!
Day off tomorrow so more time to get stuff done!
So today I thought I would check all the locks work as it has been 4 years since they were used. Both doors were fine so greased up the barrels, but the boot lock was not. I managed to get it moving but wasn't unlocking with the key properly so had to take the boot plinth back off and remove the lock. I don't have a clue why I didn't check it before I fitted it but oh well. Anyway stripped to lock down and pulled the pins and micro springs out and soaked it all in WD40 the barrel was corroded so it was just holding the pins in all the time.
1C42146C-99D1-4D0A-AFBD-DF68FF32AAFD_zps
Put it back together after removing all the corrosion from the barrel, works spot on now.
9AB5517E-1E8B-401D-8C50-E43FB10B98EF_zps
Then dug out the looms....
Yeah... What a mess! I forgot what a state it was! All the tape was covered in oil and was just soaked all over with oil!
29B47652-1B86-49DF-A1BE-2AB4280F6245_zps
Anyway got it laid out and when its all spread out there is nothing to it! Working on BMW's everyday with massive looms makes you realise how simple polos really are!
D0556640-D031-4DB0-AAD3-362850B0A76B_zps
Got the wiring diagrams out and started going over all the looms making sure there was no high resistances it the cables all seems fine but part of the loom are just messed up!
Lots of these!
D5DDCB7E-AC6F-4CAD-98E8-E49D55607EF4_zps
Also part of the main dash loom has been cut then re-attached but some of the loom has quite thick wires from the ingnition switch and they have just attached them back together with smaller amp profile wire... Not good, so need to repair a lot of the loom with the right size wire. Lucky I have a spare mk2 loom from my old bready I can take bits from.
A464547E-1583-48CF-8D6A-FB70395D6859_zps
D6927AE3-A0A3-4B49-ACD1-F15DA2A52824_zps
That's all I did today working out what I need to repair and checking the resistance took most the day.
Got my work cut out with this. Need to order my battery cable also as battery is now in the boot.
Edited by RyanC
I thoroughly enjoyed reading all of this. Unbelievable work!!!
Can't wait to see the finished product!
Had work this morning so not a lot done today really.
In the week I ordered two new earth straps. One for the chassis leg to engine mount and one for the coil to gearbox mount. Bonnet Earth strap was in okay condition so I kept that.
New ones I ordered are custom made so measured the old ones so they would be the same.
4A4294B3-38B3-4A27-AF27-C15C6AD07179_zps
Treated myself to a soldering iron today as I needed one for work anyway. Thought I'd solder the ends of the straps.
8B31ACC0-0446-4C66-B5D8-FE2561F0AE1E_zps
All three straps got new heat shirnk!
1522901D-BD54-4040-8FE9-8FCA5C796B10_zps
Then got them fitted!
2EDDB610-E356-4B8C-B5C9-711E3625B27B_zps
7286572C-EDFE-46D2-A474-E05FA6230E0E_zps
The gearbox mount I had to remove as it wasn't earthing on the gearbox because of the coating on the mount, so removed the paint from the flange area so it can earth out on the box.
48679AC2-027F-4844-B778-0C723A7B2057_zps
All sorted! Hopefully will start on the loom tomorrow.
Edited by RyanC
Where did you get them made? Whats the measurements for all 3. I need to do this
Looking fantastic sir. A real testament to your years of hard work.
Looking good dude! Can't wait till it's finished!
Looks really good Ryan!, I need to do that with my boot lock as mines stuck open. Good to see another G looking good!
Thanks guys
Kiran, there off eBay a guy makes them as you order. Bonnet one is 280mm, coil one is 300mm and engine earth is 180mm.
Few more bits done last week.
New seal for the tank sender inspection cover
72C3975F-F93C-45E5-AD96-5CC0F94BB746_zps
Rear lamp loom checked and re-wrapped.
0E765150-6536-4854-BD6F-15D93D69A25F_zps
Boot door card back on.
B97A9FFD-6472-473C-A81A-B01EBBCEC803_zps
Then loom running front to rear fitted after checking it and wrapping it.
92397F48-C457-4065-81D4-56944B21B4B2_zps
Now the bigger looms need sorting! Won't be as bad as I thought. Ordered battery cable to run front to rear and connectors, junction box etc after working out what size cable to use and how I'm going to set it up but all sorted now. Bought proper unisulated crimp terminals too to look OEM.
Chip also ordered from PPP. Need to work out where I'm going to put the water/meth injection tank too.
