Ryan's Tornado Red G40
Ryan the level of detail is amazing.
I saw this car what 18 months ago sitting in your garage? I cant believe how many hours you have put in on it.
Would be great to see it when its done. Will you be going to the Polo social in the summer?
PS. your old engine and bike carb set up is running beautifully.
  • Replies 276
  • Views 42.3k
  • Few extra shots I took today. Got all the suspension tightened up today aswell then got my wheels on New genuine centre caps from Germany! Found a bag in with the mountain of polo part
  • so much new and shiny
  • Lifted the engine in with old hooks as I didn't want to damage my nice shiny re-zinced ones also fitted my dipstick that I also got zinc plated ha. Powder coated water pipe fitted, and yes all new
This is truely an incredible build. you have the skills knowledge and attitiude that work very well. Keep it up
Thanks Guys,
Glad its all running now! Yeah was quite a while back. I'm aiming to make it to polo social yeah, if everything goes to plan haha.
So I had a week off work so got quite a bit done.. Never as much as i want to but most of the wiring is done.
While I remembered and managed to borrow the DTI gauge from work. I wanted to check my exact TDC and mark it on the crank pulley for reference when setting up ignition timing and vernier pulley. Found the d-well and set it in the middle.
175F1656-7525-4AD4-BFA3-4D0BD89AC4FF_zps
mark on left and right 5deg before and after TDC.
5F8AEA00-6DE5-46DA-9468-AC09730005C6_zps
The pulley mark is well out from standard but it is off a different engine.
Plugs in BPR8EIX NGK plugs and fitted the Magnecor KV85 8.5mm leads.
15E1CE69-FD2F-4429-AB6D-33F463F1DFB7_zps
618CBEAD-D431-4596-BFCC-F4FF4DF4F585_zps
Got a carbon weave effect filler cap because why not ha.
3AF7536A-5CCB-490D-82D1-C019ECB7F24C_zps
Reconditioned Volvo T5 310cc injectors ready to fit.
55294B32-C4A2-4572-9228-F6F3380DA034_zps
Rail cleaned and injector loom wrapped
A0FA3386-A029-4F70-A963-EA7C60857755_zps
Injectors in rail.
68E08C20-BFAD-460C-9B83-C6B88FD88F52_zps
All fitted.
2A7BE91D-D671-4387-BB2C-9A4BE9DED1D8_zps
Started on the throttle body cleaning it up and fitting a Boost switch and removing the what switch.
Took the what switch off.
A01E6DDD-1340-4761-862F-5FDCD1644C45_zps
Drilled a hole in the side plate to fit the switch.
E3818284-B6D5-4353-B6B9-D2C82F76434B_zps
Test fit.
A1792DFF-D4BD-4EEC-B163-F8B110E00130_zps
8C516110-25C8-4C80-8389-0E8C8FA6720F_zps
FF34B5ED-A2FC-4FE4-8443-7905EFE0C749_zps
Nylon washer to space it out so it do not move it the side plate.
Put that to one side for a bit and started on other stuff.
Little progress pic.
400C88CF-E254-42BC-9FB5-BCA5F45F5B7A_zps
new little lock washers for the door check strap pins as the old ones were missing and the pins carried on coming out.
6597758C-1AB1-4CE7-BC6E-B946CDC81BD5_zps
Got the battery tray fitted. Put some rubber of the bottom to help it sit more flat and seal of the bolt holes.
F95D2ABA-DD2F-4759-85D2-B74D8D3BFB4F_zps
Made an aluminium plate as I didn't want the battery sitting on the 4 bolts holding the tray down.
07646341-DDE6-4CE5-93D1-5B35ACED16A1_zps
37B6D195-90E9-4041-9D20-FC9066FBA926_zps
Loom time... What a mess.
00326224-E8B7-4CD4-A69B-A61408A509E6_zps
D72D2374-2C1D-483E-9C1F-B82F0236B79E_zps
F3F5A1EB-BA5E-443C-8611-279F8A2C73DD_zps
EECB5D3D-4EAE-4B10-9044-C5785E9E4862_zps
81136A6A-A789-4987-9352-BC76D9EC1E83_zps
C7C017FE-9D94-40B3-A261-5EB65F3421D3_zps
BC287260-B4E5-42D8-837D-0C429A4A6BD8_zps
Didn't get that may pics of the repairs on the loom as I forgot really ha but here are a few. New temps sensor plugs loom cut, new wire put in with new terminals.
201DC884-419A-4E08-9961-03CE191BDFE6_zps
Same with the oil pressure sensors.
0447627B-C2CC-4FBF-8CFC-FC7C4A3DA25C_zps
some of the loom repair work
E57E2328-F9A7-40EB-8C1D-1B8166C3E3A1_zps
60D30925-61C3-484F-AE4F-46CE84F7E094_zps
All repaired. Took 4 whole days, a lot of head scratching and soldering. All solder repairs a double checked them to make sure they were good and checked resistance. Then heat shrink on all repairs no sticky horrible tape.
All looms rewrapped in cloth loom tape all circuits checked.
B16FE84F-2333-430E-BE35-48455EB3CD52_zps
Then for the power supply. Using and junction box where the battery use to be to branch off of. M8 eyelets crimped with correct tool to the extended main loom. Then heat shrink.
E34801DE-F33A-4BD7-8EAD-3D2D70996B6F_zps
Junction box fitted to the earth point.
8AE7A268-C893-4951-91B6-1F1A68707751_zps
Also drilled a 10mm hole in the old battery tray base so I can fit this tool to make a perfect 25mm hole.
EEDF1C46-DACC-42DC-9D0A-AA93E1C6264A_zps
One side on top and one underneath then just tighten it down.
FC830569-2245-4A03-A523-A142ECCC169D_zps
9D0DA679-399C-4408-B766-F9A200C8DDFD_zps
One 25mm hole ready to fit a cable grommet for the battery cable.
85658092-0121-4F71-AF60-7FE9F632D82E_zps
20C678A5-2D4E-4685-98A5-BAF06DB4930B_zps
Edited by RyanC
Then got on with making the battery cables. Borrowed this awesome tool off a friend. Works spot on make everything look OEM.
7AE244E0-F738-4CDE-969D-794139EE3D1B_zps
715760D2-DCBA-4B1B-9230-DFF3F88B3CDA_zps
One crimped end.
13ED9917-B861-4E2E-B86E-CE829E65A71C_zps
Same with the earth cable to battery.
80631A39-BF28-469B-8369-BCB90084AA0E_zps
Then all crimped ends soldered just because. BIG soldering iron needed to do this.
12256AA3-3A0C-44B4-94FA-015F4AFE9FDB_zps
817ADF76-F1A8-4E4A-ABC3-4BECB112F652_zps
Then all heat shrinked
647108B0-8316-438A-8D79-C1B0D1E7BB99_zps
Main cable routed down the drivers side.
0208327A-58B6-4582-9C7B-ED96FE32A986_zps
All connected to the junction box
909774F7-320D-499E-92B5-F26347FB47FB_zps
P-clips using to secure battery cable to drivers side. Will get some pics soon.
Starter to alternator loom made. Old vs new.
5D49F33F-1B13-4083-9DE5-DCD723C3B72F_zps
F30F9608-5A44-4AB2-8611-B91C27BD38D9_zps
New high temp loom cover like what is used from standard. Again all end crimped, soldered and heat shrunk.
D0621129-3AA0-43CC-8AFD-CCFA903239FB_zps
E3D8799A-8FED-4359-9E5E-A55F8DF81608_zps
Then made junction box to starter cable. Heat shrink used where it is close to body.
Both ready to fit.
67E02A3C-89D1-4A1A-9B8C-80D4162B6549_zps
No pics of them fitted yet but nothing special just replacing the old stuff.
Looms all back in. ECU mount re-zinc plated.
81FED6DE-13BE-4BE5-BAAC-9A857AAC23F6_zps
Stripped the Throttle body. I'm glad I did because the spindle bearings were full of flakes of aluminium from when it was machined to 51mm
F77A03A0-0DFF-4BFF-B0D4-A868DAC81FB9_zps
Test fitted to check port match.
3869B0BF-1882-47FF-A74A-75541E56D822_zps
Boost switch soldered into old what switch wires.
707D31D7-0A1D-4AAE-BD34-0EA863653AAD_zps
all ready to fit, just need to set the switch to 6psi.
6D610A1E-CCB2-4C8B-B20C-573F523C939F_zps
Motorbike fascia heat shield that i got for the tunnel and the bonnet where the turbo is. Foil tape around edges.
F30678CD-AD66-49F0-93C3-4A47C8EBFB0E_zps
6D7BCE6A-6C99-40CB-B7FA-F85BB2A80CFF_zps
Tunnel all done too, got some more on the way for the tank.
1A8717F4-3FEE-49E4-822F-CE9FC8F1D409_zps
0443D6B9-458C-43D1-9673-0FD85F221B48_zps
9E38E443-E1FD-41E5-8980-E6D30C95316B_zps
Back to work now after a week off but in the week at work I painted the throttle body. So this weekend I put it back together. Bearings greased after cleaning all the flakes of aluminium out. New butterfly screws used thread locked and ends burred over just incase.
5B943596-B4A0-4513-8CC7-EA13C46BF5E3_zps
B038EAEA-A4F2-4012-8CD5-B5315A021E8E_zps
And fitted, new gaskets that I made from gasket paper.
2CDCC64B-7AC5-424A-95DA-95FDD95994C2_zps
7CFE8CEA-DA1F-4CFD-9B68-55E141D6DE70_zps
NOS driveshaft heat shield
32439799-8C65-45B2-B71A-D00D3C8BA7EB_zps
Dug out the PPP system, new gasket and stainless bolts for the flange.
9FA891AE-3B17-40DF-9AA7-417F4F70A7B7_zps
Was going to use/make my own hangers for the rear section as they are good a snapping rubbers but decided if I get some powerflex poly hangers it should be fine.
70C5CC34-528E-44D8-8479-D5D8C6A55C1D_zps
7ED8AB72-1B1D-4423-8566-16037E940095_zps
Ant going nowhere!
Test fitted system, ready to down pipe to be made next weekend.
23C91D57-1061-4C10-95C5-6CE4F45D1FC0_zps
D1EDA862-8ADB-40D4-A5E1-F6C1E5823457_zps
1D94FF49-1EC0-45A8-A447-9D34938A0452_zps
E031088A-8B69-458D-83CB-2E9BD9797593_zps
I remember seeing PPP systems on other cars hanging quite low. But seems to be tucked up quite nice. Will need to make a bend in the down pipe behind the sump as its so high in the tunnel. Result!
wow
Ryan, all credit to you but it looks like your Polo is going to be way beyond better than factory fresh by some margin!
Your going to need some magazine articles on this.
If this thing doesn't get in a magazine at some point I will eat my own jeans. The attention to detail is astounding.
It's almost a shame to drive it! Belongs as a centrepiece in a Polo museum.
I'd pay to see that!! ;-P
Thanks for the kind words people! 🙈 I never planned on going this far with it but it sort of snowballed 😂.
It would be nice to get it in a magazine but I'll be using it a lot so I don't know how long it will look as clean as this for 😐 I will be taking lots of pictures when it's finished before I use it to remind me how shiny it was ha.
Few more little bits done.
Peter James ( with the 4wd bready in the making) has been a big help with a few little bits I've needed making. lots of little adapters etc. He made me this awesome turbo inlet adapter to fit a 3" intake pipe too. I just gave him all the measurements and how I wanted it to be etc. So happy with it! Better than a pipe reducer.
542587F9-3CAE-4112-830C-AE812F1BD42B_zps
7AD12546-781D-434C-AF23-83404A08D9E8_zps
FBDAC4BA-C3CA-441B-A92C-B0041E76FB36_zps
B7F199CA-6F89-4A23-B15A-8D6D6B48DB15_zps
104190CD-84D8-4D9D-9310-91D2E6DA95B3_zps
3436F4CA-C195-4666-A511-DED4279F972A_zps
3 grub screws to hold it on. Internal diameter same as inlet of turbo to match.
Throttle cable grommet was dead so measured the hole a got a new grommet
4ADE052F-DDA7-477F-B869-4B704D27A12B_zps
Then fitted the cable
6E2CC25F-510B-40D6-B0C4-BAE4668AAE42_zps
Wired in the uprated fuel pump
ED875699-448A-4641-A05F-975BCB0BCD5E_zps
I put p-clips on both handbrake cables at the rear beam to hold them up as they hung quite low with the cable adapters, a lot neater now.
EA5A347B-8079-4F29-85BD-F3684A443A98_zps
Powder coated lower brace fitted
8CD8B729-33C3-41EE-B196-9B1B531F55D2_zps
Put heat shield on the fuel tank
6AC297FE-DE1C-42AF-A77F-6B01F1889C37_zps
42BB8B00-E5EA-44B9-8C42-6E6315FA5578_zps
Hand brake cable needs to be protected and secured yet.
Fitted both front door cards today.
Made new membrains to make them water tight.
Then got the black vinyl door cards on. As my seat colour has changed G40 door cards would look crap. Also always liked black vinyl mk2 doors cards. All mk2 trim fitted too.
74C03F76-4286-46FE-A803-E1329366E9C2_zps
4726B9B9-A521-4C09-9667-395111C7F3A2_zps
Love the more retro look!
Edited by RyanC
Ryan where did you get your new header tank from?
Nice work mate! Especially about the wiring, funny enough I've just messaged pete about making me a k03 airfilter adapter like yours 😂, if i was running the exhaust rubbers like you with that system id weld a bar inbetween the 2 hooks to stop them bending inwards 👍 But good luck, hopefully see you at polo social 👌
Edited by Buxton
Header tank was from VW heritage about £15
Thanks man! Yeah wiring was a nightmare! Ha yeah Pete has done a few bits for me always spot on . I'll see how it goes seems pretty solid tbo, can always modify it if it dosnt work..
Will be there next year I hope
lol + 1
You don't happen to know what their part number was? as under Polo 75-94 there's nothing, cheers
Have you looked on Vagcat ?
1H0121407A
I will try and update this next week, bit behind [emoji849]
I got so excited when your thread came up with your name too :tear:
werent the only one :D :D :D
