fk powerlooks wiring
hi guys i recently bought a set of fk powerlooks. i am havin problems with the wiring as i dont know what goes were iv got a 96/97 model polo without electric height adjustment, i know that two of the plugs from the new wiring loom which came with the powerlooks go to the back of the headlights. i need some help from you guys who have already got them and fitted them to your cars as this is the first time I'm fitting them to mine lol il try and upload sum pics of the plugs which i aint sure about where they go and it would be a great help if someone could shine some light on this for me. and what r the two red wires for with the connectors on the ends. where do they go?
I'm not sure where the black plug goes from this picture can someone shed some light on this for me as you would have probably have done this already. if I'm right in sayin the two white plugs fit directly into my original wiring loom which is on the car? can people please get back to me asap as i want to put these on as soon as. :-D
Edited by normz_dub
  • Replies 25
  • Views 3.1k
The black plug looks like the standard headlight connector The pic is for the 7 pin connector but the wiring for the basic headlights are the same pins and wire colours
so were does that black 7pin plug, plug in? cos mine are the four pin headlamps n i dont have anywhere to connect them to :? n my original connectors for my original headlamps r like a oval shape n the ones that have come with the new wiring is like on a square block sort of connector if that makes ne sense to you.
The seven pin is on the headlights that have the electric beam adjust motors in them.
so i wont need to use that plug then would i cos i dont have the electric beam adjustor do u knw what the red wires r for in the pic? this is longer than i thought lol
that wiring loom should connect to the original passenger headlight plug and the other two go the the new head lights. its so when you put on full beam the dipped buld doesnt turn off as it would with your standard as its a now a H7 bulb not a H4..
edit : the 2 red wires go to the positive terminal on the battery
Edited by dom604
yeah iv had a look at that, u talkin about the lil white square sort of connectors yeah? i want to know where the other black connector goes with pins init its in my pic cos theres the two that go two the back of the headlights n then you got the two connectors which go to your original headlight connectors and then you got one left which I'm not sure about and thats the one with 7pins init
take out the headlights and use this diagram and the wiring sequence below...
use the loom provided with your lights like in the picture above
the plug that giving you bother is the one in the top left of the diagram as it isnt the right shape for where it connects to....chop this plug off and then chop off the plug that this would be going into and wire or solder them accordingly...
the ones you need on the car loom are:
Brown = earth
white and black = main
yellow and black = dip
grey and black = side
wire them accordingly
yellow = yellow/black
brown = earth
white = white/black
twin grey = grey/black
there are 6 thinner wires if i remember correctly in three colours red blue and black discard those as this is for the headlight adjust ment which cant be used.
hope that helps
this is only for pre 98 cars post 98 looms plug straight in without need for wire chopping etc
Edited by chrispy
Brown = earth
brown = earth
white = white/black
hope that helps
so u c the plug in the pic that iv got up with 7pins init do i need that? if i do what does it connect to? the one thats rite at the bottom of the page
bump
can ne1 else shed nemore light on this for me please really need sum help
Which bits are you stumped with and maybe I can help? :) Also chrispy was the biggest help when I wired mine! :D If you just follow his instructions then you'll have them wired up in no time :)
I'm jus stumped on the bit where the 7pin connector goes my headlights r 4 pin i knw that the 4pin plugs go into the existing four pin loom which is on the car at the min n the then you got three black connectors 2 of which go into the back of the headlights. the other connector which i aint sure of is in my second pic can someone tell me where that goes
help!!!!!!!!!!!!!
I'm not sure what else yoU need to know its all there.
Read my instructions again you chop them off and rewire them accordingly
I know I've helped tons of people with this ow but I can only remember what I did when I did it and that was like 7 years ago, VWking has recently done of based on my above instructions no bother :D
Christian
Got em sorted yet mate?
lol sort of just gota get two relays for them hopefully tommo n then fit them this week will call u need to speak to about converting them to rhd's remember the convo we had a lil while ago n by the way do urs say depo on the lense by nechance? cos the lights i got do :? u still on the same number?
Edited by normz_dub
Rather than starting my own thread.
Quick question to anyone who is running powerlooks.
What bulbs are you running in them?
Do I need two H7's and one W5W LED for each light?
Correctamundo! You need 4 H7 bulbs all together, 2 for full / main beam and 2 for dipped.
Also normz_dub did you get the wiring sorted out in the end? :D
Edited by VWking
na mate still sortin probs sort it nex week nw as the cars off road at min lol jus aint really aint been bothered
Edited by normz_dub
right guys i wired these up to my mates polo his got a post 98 polo so the wiring jus plugged straight in and we thought we were ready to go but the only thing was only 1 light came on on both headlights. :? it was the little screw in bulb that came on non of the other bulbs came on dont know y this is. can some shed some light on this for me plz we checked the bulbs n they were fine so couldnt think of nethin else come on guys a little help here plz
can ne1 shed ne light on this? really want to get these lights in asap its starting to piss me off :angry: so if ne1 can it would be a great help and would be much appreciated
Edited by normz_dub
Have you got the relays connected? If not then for testing you could bridge two of the four pins in the connector for the relay. Iirc one will have two yellow wires and one will have two white wire, as well as having a red and a brown. Thenswitch them on, the should work. If you have the relays then make sure you connect the red wires to the battery + post. Also when using this loom one an earlier car that used 4 pin lights, best thing to do is chop off the male plug and the passengers 4 pin female socket then solder the wires together as above. You should have three wires left over (red, blue and black) these can be left to the side.
HTH
  • 7 months later...
Brown = earth
brown = earth
white = white/black
hope that helps
Hi,
I am considering upgrading my 213 000km ran headlights to see the grave, updating them into something simply due winter mode and I don't see anything.
Glass from 1995 is gone matte, moist is all over, and the paint has gone matte I suppose. The FK / DEPO / AD "powerlooks" are by far one of the better looking options, and I'd want to combine them with OEM white turns up front to dampen the "crystal clear 2000 style".
But,
Atleast my car has the 4 pin connectors for the OEM headlights. Wouldn't it just be possible to take these out of the OEM lamps and swap for the 7 pins at the powerlooks?
You can do that, but it is easier and better to use the supplied harness because the wiring is better and will greatly improve the output.
I would just use a cut off connector or solder the new harness to the existing one before the original one so this way you will.have both the 4 and 7 pins
  • 1 year later...
I have just brought some of these head lights and they are 4 pin and the car is 7 pin how do I fit it and where do I splice the new loom in is it on the passenger side plug
