mk2 1300 s
hi all,
i have a mk2 polo coupe s that I'm prepping for road rallying (been doing tis for a few years)
but i dont know much about vw engines
is the "gt" cam much of an improvement over the standard s cam?
the class i run it must have the original engine, etcetc, so no bike carbs, super/turbo chargers or larger engines allowed....i know i know, lol
I've heared swapping the standard cam for te GT is an improvement?
this correct?
cheers in advance
Monty
  • Views 933
Go back to playing Froza. :lol:
GT Cam would require an Electric fuel pump, not hard to wire in, done it to the other polo here.
Weber carb is another improvement one over the stock pooberg carb
You could do alot of things but it really depends on your budget and the regs.
More money = More options
That's how motorsport works, as I am sure you will be aware
gk inlet manifold , weber replacement carb like a dmtr , twin outlet downpipe and mainfold , g40 system fits them too
max off this forum is currently selling verinier camshaft pulleys.
also, if you need to upgrade handling, there are a lot of upgraded bushes, fitments, coilovers etc. all reasonably priced, and plently of guides on this forum.
i suggest you read the MSA rules properly, you could run a 1400 16v aslong as you retained the standard inlet manifold/throttle body assembly
thanks for that all, but i want to retain the original engine
will take all advise on board though :)
