mk1 golf clocks into mk2 polo?
I've noticed recently that the speedo clocks and the layout of the clocks in a mk1 golf look identical to the ones in a mk2 polo, is there any reason nobody has fitted them inot a mk2 before?
main reason i would like to use them is because of the higher mph gauge
I'm led to believe they will go straight in, not 100% sure mind.
Many people have upgraded to the 120mph speedo, You can just swap the speedo it's not necessary to change everything. There are some wiring differences between mk1 golf a mk2 clocks mostly depending on the age, so swapping the golf speedo into the polo cluster is usually easier.
The only difference between the 120 and 100 mph speedo is the counts per mile (number marked at the bottom, usually 1578 or there abouts on a polo speedo) is lower (around 1540) therefore the golf speedo when fitted to a polo will read higher than a polo speedo by approx 2.5%. Not a big problem though, changing the rolling radius makes a bigger difference.
Perfect answer cheers bud :)
