What to look for when buying a 6n2 Polo?
Hi,
I've got my eyes on a 6n2 Polo and was wondering what to look out for when going to look at it. So far i've been told to look out for the pedal box, gearbox and rust. Is there anything else?
The car is a 2000 plate with a 1litre engine :).
I currently own a Lupo :).
Thanks.
  • Replies 14
  • Views 2.8k
Yeah all 6n2's were recalled per 2004 as the pedal box was originally only spot welded and it needed to be rig welded for strength.
Also look out for rear jet as sometime it comes loose and can mess up te boot lock system,
3rd brake light has no incomplete led's.
If you can take vagcom do!.
Lambda sensor always fail but this will put engine management light on also abs sensors fail which will put the abs light on
Check the electric windows come up smoothly as the window electrics in these are sh!t
Check for oil spots under the car once it's mode from where it was parked
Ask for a test drive and make sure it reaches temp !
Te locking barrels can go quite easily aswell so check them both and also the boot lock pump in the boot can fail sometimes so listen out for it and make sure it doesn't take longer than say 5 seconds to sound off from locking and unlocking
That's all I can think of at the min
6n2's should not rust as they are galvanised. its not full-proof but with good condition factory paint it wouldn't come through yet. any rusty 6n2's have had repairs done and may have been in a crash.
I've had tow 6n2, peddle box went on my 1.4e with low mileage. Gearboxes are worse on the gti possibly due to them not being able to cope with extra power.
Electric windows and central lockking are alos prone to playing up.
I'm not certain that they were galvanised? Lupos were not so i cannot see why the polo was. The Audi a2's were.
Audi A2's were aluminium in their entirety so did not need galvanising but the 6n2's are fo'sho but good call on the central locking and windows.
Can i find more on the boot locks anywhere?
Mines is buggered and i cant get my boot open now!
Gearboxes, how much are they to replace yourself including tools required - looking for a quick response?
a reconditioned box can be had for less than £200.
Are they easy to fit? I.e, could i do it on my driveway?
there is a guy on another forum (uk polo) who has just done it on his driveway using axel stands and the right tools
you can do it yourself but I got someone else to do it at the time because i didn't have the time to do it.
Where do you get these reconditioned gearboxes? I've had a look on eBay but not much is coming up for them :/. Does it matter which engine code you have and will a 1.4 gearbox fit on a 1.0?
normally the company will take your box and refurb it or sell you one
mine cost £250 to be refurb'd
won't the ratios be messed up if you do that? probably best sticking with the same engine code
Was that a vag specialist? Once it has been refurbished, is it likely to happen again? That's what i was thinking.. Afaik, it's the same gear box which is why i was asking hmm :/
they normally offer 6-12month guarantees
i was told the failure was due to the rivets being weak and these are replaced with hardened bolts when the box is recon'd so it should not happen again
different engines will have different gearbox ratios
