Polycarbonate windows for Mk1-3 Polo
This is for a full set of cut to size side windows including slider's if wanted and a rear screen.
These are made to FIA/MSA specification, an excellent weight saving to be had
Mk1 - £210
Mk2/3 - £220
Individual prices are...
6x Side windows with sliders - £170
6x Side windows without sliders - £145
4x Door windows with sliders - £125
4x Door windows without sliders - £100
2x Rear quarters - £70
1x Boot window - £75
Price are all in, including delivery. Made to order so takes a couple of weeks to come through.
Can be ordered tinted, with hard coating and any extra's you may wish.
Nearly any car is available off the shelf.
  • Replies 37
  • Views 6.3k
what sort of weight would be lost by installing these??
Cheers!!
Not sure how much each of the windows weigh but very good gains to be had as its weight higher up in the chassis. Will make a noticeable difference.
are the windows coupe only or can you get breadvan ones made up?
Breadvan too...
How much for just the 3 back windows?
£160 delivered
what colours do they come tinted in phil I'm very interested probs be in the summer though and is that for all 5 windows: 2 front sliding, 2 rear sides and rear window
Will find out on the colours, and yep 5 windows.
Are these polycarb or perspex as I'm pretty sure Perspex would crack, also as far as I'm aware polycarb comes in a light smoked colour or clear.
Sorry was thinking about it for a while as I'm quite curious/interested, thank you
I have seen them come in a green, blue or red tint too that's why I asked
Must of just been our supplier at my old company as we were told they could only get opal smoked or clear.
Appologies mate my mistake they must have just been shite, although acrylic/ Perspex comes in any colour.
Hi phil, looking to buy a set from plastic 4 .
Are these 3mm? also are they available with the oem black bordering..
thank you
TeZ
4mm thick. Will find out on the black bordering, sure they can be though.
Will ask on all tint colours too.
Polycarb.
thanks phil that would be ideal!
on the plastics4per site they advertise 'bronze'
assuming this is just the tinted option.
id like that..
i was hoping for 3mil but you cant get everything i suppose
Yeah can do bronze no worries, just give me a PM when you're ready.
I'm looking into the budget window sliders too..
I'm not planning to use polycarb windows on the original runners.
Sliders are included in the price if wanted.
excellent, one last question lol
Can the front windows come in a 1 piece to delete the small front window?..
Yep that is no problem, would need some ingenuity on the rubbers.
  • 4 months later...
Cheers!!
To those who have asked about the weight, and just a general sort of information bit.
My windows turned up yesterday, and from my first impressions they felt very light.
For those who are unaware, Polycarb windows are not stiff like glass, they do have a bit of flex which you may notice at high speeds, but that's just part of weight saving.
The windows will turn up like this:
The white is a protective film. it would be wise to keep them on until you are going to put the windows on the car as polycarb can scratch.
Here is an example of the flex you can expect.
obviously once you have the windows installed they will be held securely onto the car, so the flex wont be that drastic.
Now for the weight:
--breadvan windows (rear quarters)
1690g per window.
--door windows (the wind down ones)
1190g per window
--quarterlights
374g per window!
--breadvan tailgate window
1900g.
obviously bear in mind the bready windows are larger than the coupe so they may be less, but still very light. When I remove my current glass windows I shall measure the weight for a comparison.
Hope this helps.
Edit:
For those who are lazy, the whole lot comes to 8.4 kilos more or less, and as Phil said earlier, saving weight higher up should lower you COG which in turn should be an improvement on handling. Less body roll.
Edited by samwii
How much for the extended pair fronts for mk2 (no quaterlight)
Can you do just a breadvan rear window?
  • 5 weeks later...
What's the weight of the standard rear 3 windows?
Apologies, will have to get some prices on the individual bits although its more cost effective to go for the lot.
