ecu fitting and mapping
just got of the phone to local dyno center and said be about £500 to fit my megasquirt 1 v2.2 and map it a day to fit and a day to map.
what do you guys think about the price??
cheers dan
  • Views 782
Aldon couldn't give me an exact figure to map mine as they said some mapping sessions take longer than others, but they said its generally around £400
i think 500 is decent price for fitting the ecu as well!
rs tuning near me are around 400 for full custom map
Depends what 'fitting' means. If it's making up a wiring harness as well as configuring the ECU and remapping it then it's an absolute bargain. But that's several days work if they're going to do it properly.
I have the megasquirt and the relay board for easier instalation. So by fitting I mean removing the old ecu taking the required wires for the ecu connector and connecting them to the relay board which is then connected to the ms by a premade harness. Then mapping the ms already has a suitable base map. Just needs mapping to match the modifications. That make sense. He said mapping charges are based on 45quid an hour.
I'd pay that tbh mate
If they're any good
