Removing the green filter
Right, the last bulb on my MK2f dash has blown, so I need to pull it all out to change them........ Whilst its all out i'm wondering if its possible to remove the awful green filter on them?? If so how do you do it??
  • Views 921
from what i believe you can sand the green off and either put coloured bulbs in or tint the dials again where you sanded
If its like the Mk2 clocks, and i cant be sure it is, the clocks are bonded and the filter is a bitch to get out. On these, the filter is along the top of the clock set and this bonding needs to be brolen apart carefully or else damage to the casing/perspex is to be expected.
MAy be different on mk3 clocks however :?
From what I can see on ebay etc...... they're MK3 ones..... But I can't be sure, all I can say is the speedo is on the left, tacho just right of centre and fuel/temp are on the right.
will have to break out the sand paper later on then..... the intention was coloured bulbs, as red car, green lighting doesn't really tickle my fancy, so i was going to pop red bulbs in. Makes for better night time driving too (makes me feel like imma in a submarine :p)
Will have to break out the sand paper & tools then!!
Just a heads up I have made some sucsess with this, the green filter was just a green bit of plastic over the top which just popped out, so got myself some standard bulbs to light up the dials so I can see them whilst night driving..... till the red LED's turn up!
As for the centre console..... does anyone else feel that the bulb holder is an incredible pain?! The bulb i was taking out exploded, the new bulb wont go all the way in??!! there anything that I can do to make this easier to live with??
