Arch flaring techniques
Hi all,
To run my summer wheels which are rh cups 15x7 with ET 37-38 I need to run some 20 mm spacers up front which means my front arches need flaring so I've got about and inch more space, both front wings need replacing anyway so I'm going to be doing this at the same time.
I can roll the arches fine no problem but just wanted to know any methods of flaring the arches by about an inch and if it's possible to retain the plastic arch trims as I quite like them.Also wondered if it's possible to do them prior to putting the wings one the car ?
Any ideas??
  • Views 1.3k
Wheel may be touching the suspension leg, shudnt need as much as 20 mm tho
This is the reason why my rh cups came with 20mm spacers up front Ben, the lad that bought them said that on standard style struts the wheel would hit it. Whether they actually need the full 20mm I have no idea cause I got coilies, but they do need spacing out
It needs 20mm spacer due to the offset of the wheel and the width, the wheel catches in the compression struts on y ppp frame so I can't achieve full lock.
I realy don't mean to be rude but I asked for arch flaring techniques not for advise on weather I should be running spacers or not! I've done all the calculations and taken measurements I could get away with 16-17 mm spacer but I already had some 20mm oneness either way the front arches need to be pulled a bit, I have already used the usual scaffold pole method still not enough.
Wind coilies all way down, put on a wheel with a baloon tyre, drop car off the jack so arch lands on tyre, job done :lol:
Just search it up on youtube loads of different ways and shows you how to do it
my personal favourite method of doing this is by slamming a baseball bat in the arch and rolling backwards and forwards till you got a nice flared arch :) just a thought so i threw it out there :p
Iccle Out
