Seam sealer?
I need to get a touch of welding done on the car. However, the area that needs to be done is covered by that tough waxy/silicon type weather seal. What is this stuff? Because once I have had it welded, I want to use the same gear to both protect, and blend with the orinigal finish. This is on a mk2, and has a dippled finish
Word
  • Replies 8
  • Views 1.3k
try tiger seal mate thats a seam sealer that seems to be used alot
Where about on the car is it man? Most likely if it's a dippled finish it will be factory stone chip paint.. I'm reapplying it now to mine after taking it down to metal to weld. It's going on the front and rear valance.. the lower part of the sills.. the bottom of the engine bay etc.
Yeah, thats the stuff. Where can i get it/who sells it?
prime the bare metal ..epoxy if you can afford it
then stonchip with a shutz gun will give the stipply effct , ajust the pressure to to alter the texture
http://www.ebay.co.uk/itm/U-POL-Gravitex-G...=item27c3fe1854
http://www.ebay.co.uk/itm/Sealey-SG14-Ston...=item51962e29ac
brush this over any seams /gaps with a cut down paintbrush
http://www.ebay.co.uk/itm/UPOL-GREY-STRIPE...=item2a18199ab3
Cheers boy! I take it that gun screws onto the top of that bottle of gravitex yah?
yes that gun fits those style cans , screw on fixing
make sure it says overpaintable if you want it to dry as you can also get some non drying cheapo stuff that makes a mess
Thanks for the heads up. Definately needs to be paintable
Thats not shutz the factory finish its a sprayable sealer toataly different in texture but proper spray sealer guns are rediculously priced but 3m do something very similar in a sachet that has agun that clips on the top
shutz is like tar and it is paintable but the paint cracks as it always stays flexible and stone chip doesnt give anywhere near the same texture and isnt a sealer ist used as a base under paint to stop it chipping hence the name.Sprayable seam sealer is quite hard once its cured thats why when you remove it its tuff not sticky like shutz
I you want as close to factory finish i wouldnt use shutz or under seal id use the 3m stuff ist still a spray sealer like factory but the gun isnt adjustable like the factory one would be but with carefull application would look pretty close to factory finish and is made to be painted over
http://catalogue.3m.eu/en_eu/eu-aad/Sealer...prayable_Sealer
you should be able to get it any body shop supplies
failing that you can get a brushable seam sealer your local motor factors should do it brush it on and dabb it with a brush dipped in panel wipe can give a similar effect (panel wipe stops it sticking to the brush) you can smooth it out this way too
luke
Edited by ahh claudia
