aee 1.6 mild steel bike carb inlet flanges.
had one of these laser cut up for my project. but now are surplus to requirements
will allow you to make up a steel maifold using this flange. perfect for bike carb manifolds, supercharging, or turbocharging applications.
cut directly from a gasket as a template so a guaranteed fit.
can also supply the correct size tube for the runners for an extra fee.
understand they fit other 8v engines, but this would be up to you to check, as i dont have this information to hand.
picture shows the gasket used to cut.
these have been made from 8mm mild steel, and will allow good weld penetration and wont distort.
dimension of the ports are 36mm, and the ports are 46mm apart opening edge to opening edge.
asking £15 each posted.
would cost a lot more to have these made.
three available
pm me if interested
thanks
pictures below:
Edited by madseb
  • Replies 22
  • Views 554
bump
one mainfold flange provisionally sold to "mylittlepolo"
one left
should be collecting either this evening or tommorow.
measured yet?
measured yet?
not as yet dude, heard they have a bit of a bcaklog on at the cutters, so hoping to collect on thursday.
ill let you know asap
cheers
no rush mate dont worry :)
just had the phonecall picking these up friday.
bump for pictures
bttt both still available
How thick are these please? Cheers
plates are 8mm thick as stated in the advert. more than enough to get good weld penetration and prevent distorting.
thanks
still here,
honestly thought these would have shifted by now.
bump.
two sold one remaining.
I just thought I could fit tube inside these to make up the size variation of my ports to this.
Have you fitted one to a head yet? May need to make a manifold for my throttle bodies
no unfortunately, work commitments have taken over. so wont be persuing this project.
i have the correct diameter tube available aswell for anyone interested.
one manifold plate left.
thanks
If no one wants to take the last one it would be rude for me to refuse it! What size is the tube needed fella? And how much for the tube with the plate?
cheers Ash
I was just gonna say I'll take the last one to make a new mani for my ITBs
you take it then dude, i wont be doing a 16 for a while!
16? Lok.
OP pm me your PayPal mate
hi guys i have the correct diammeter tube, but obviously the postage will go up as it sort of bulks the package up a bit.
looking at about £25 all in for the last flange and the tube. thats 4tubes cut at roughly 4" each. if you need more let me know
can drop me a pm.. thasnks guys
Pmd
all flanges now sold, this can be deleted
thanks all
