polo nz help
hi guys bit of help needed seen a polo for sale with the nz engine the guy said it came from factory but its 4 speed which i thought nz had 5 speed gearbox also what model was the nz engine in as this is a cl model help would be great as I'm lookin to buy the car but dont want a car with a engine converson
  • Replies 9
  • Views 876
The Mk2f was launched with the Mpi NZ 1.3, with the Spi phased in later.
It's a misconception that all 1.3's were fitted with a 5 speed box. It was an option on both 1.0 and 1.3CL's (excluding saloons) for the first year or so when it became standard. Some NZ units also found their way in to early Genesis trimmed cars, which were introduced in mid '92, The Genesis spec meant these were to have 5 speeds as standard (1.05 Genesis only had 4).
Check the data sticker in the service book if it's still present.
Serious knowledge there! ^
Mines a '92 genesis NZ
spot on massive thanks fella least i no it should be bout right first job 5 speed conversion :p
i've got a 4 speed nz too! parts arent easy to find if they are nz specific e.g. coil, but its a good engine overall :thumbsup:
well I'm trying find out a bit more towards what i need to do to make it a gt lump basically with a few extra tasty mods I'm hoping to get 90-100bhp area but not sure if its possible
I think after buying all the relevant bits you'd be better waiting for someone that's breaking a gt an just put the engine in yours mate
the nz engine looks the sameas a gt but has nothing in common except the injector rail it uses and the air intake up to the intake manifold which is different, gt has different compression, different cam and a slightly different cylinder head and of course it has the gt gearbox
to make the nz more similar to the gt you should put the gt cam in and the gearbox on for the short ratios for better acceleration, but the only way to make it fully gt is by guess what..... putting the gt engine in :lol:
but as i have found getting the cam and gearbox will not be easy or cheap
you can generally get a cam quite easily at the common price of 50 pounds. they never lose value, theyll always be 50 quid though. gearbox's are a bitch to find though
once they go up they sell fairly quick though!
