Getting More Lows?
Guys, any suggestions on how to go lower? Already done springs and shocks and gonna go lower profile rubber.
1990 Bready on standard 13s
cheers chaps
  • Replies 33
  • Views 2.8k
angle grinder!
Haha! was thinking of maybe taking a coil out but i think the sump will then scrape and the exhaust will definatly scrape
I'm running 70mm front springs with 1 and 3/4 coils cut out, and low profiles on 13 inch wheels.
haven't had any sump issues yet
Not completely sure what my fronts are they are the lowest ones i could find lol
Is 70 the lowest?
Exhausts need to be modified to tuck up closer to the body if you want proper lows, the sump shouldn't really be much of an issue if its just the standard engine in it but if you are worried about it just weld a plate on it to give it some extra protection
yer gonna have a look at work on the ramp next week get it all tucked up
What's the point in asking how to go lower, then when someone tells you, you say you dont want to cause you'll get scraping issues?
Dont go low if you dont want to scrape...
Lower the road too
remove the dampers and leave it sat on springs... :ninja:
Exactly what i thought
No i said i didnt wanna fuck up my sump, kind of a important bit. i dont mind scraping the body, but at the moment I've got like 2 inches of clearance
You mean remove the springs dont you ;)
i wouldnt like it sat just on a spring, it will fall to bits, nothing holding it together haha!
OH WAIT HE'S GOT A LOW POST COUNT LETS MUG HIM OFF
Why has no one mentioned coilovers?
coilovers
coilovers
what are coilovers?
Icant afford coilovers to be honest.
seen and heard of mk1 golf coilovers? Any info on them?
coilovers
coilovers
what are coilovers?
Bunch of nice people...
You can convert mk1 golf coilovers, haven't really got a clue to be honest, still gunna around the same price to do the fronts as buying coilovers to be honest, use the search function there should be a thread on this.
COILOVERS
Does the sump not sit lower than the bodywork? :lol:
Sure if it wasnt for the subframe on mine the sump would be the lowest point of my car.
In all seriousness, without cutting springs or getting coilovers, you aen't getting any lower. You could use lowering top caps or get smaller profile tyres though.
yer the sump is lower so although my sump is close the actual car doesnt look that low if that makes sense.
thanks for the help guys
I'm on 70mm springs all round but 2 coils cut on the front. Would appear that one of my drive shafts is touching or has been making contact with the chassis :?
Surely coilovers wound that low will still ride just as harsh and still have tca + driveshaft clearance issues.
My sump does have a big grind in it from hitting a speed bump at 30 mph on un cut 70mm springs, would be safe to say that was my fault
you can only use the rears. they are a lot shorter and even wound to their max they're low. they require a little work to fit too.
