Annoying noise from mk2 Speedo
I get a really annoying high pitch whine/squeal coming from my speedo when travelling along.
The noise changes pitch the faster you go so I figure its something slipping and maybe vibrating.
The problem seems to be worse (it happens at lower speeds) the colder it gets.
Its definately not the engine oil warning as I've driven along with the electrics completely disconnected from the clocks. It doesn't happen if the speedo cable is disconnected and the electrics are.
Anyone got any ideas what it is or just how to fix it?
I'm having to drive with no speedo at the minute which i'm guessing is illegal and makes judging speed cameras very tricky!!
Thanks for any help
  • Views 662
Popular Days
Sounds like the speedo is bummed if the pitch changes as the speed increases.
I've got a spare set of clocks that you can have the speedo from, its on 102k I think. tenner posted?
