85' mk2 coupe s project
i'm only playing. fair enough for saving it
  • Replies 123
  • Views 7.1k
take the fuel utlet pipe offthe carb, crank the engine and let the fuel pump into a bottle, see how much fuel comes out
or take the fuel pump off (and fuel lines) and pump the drive pin by hand, see if you can 'block the flow' with your finger.
ill give that a go nice one.
if i stick my facet on there to see if its a fuel problem, will it be alright pressure wise if i have it attached to the swirl pot? swirl pot has a return right?
Yeah the swirl pot does have a return , I'm having exactly the same probs with my 1.3 although it hasn't been stood at all it has just got progressively worse over time to the point its stuck at the front of the house , if I try to start it won't go at all , if I remove the return pipe of the swirl pot no fuel comes out until I remove the feed pipe (then it pisses fuel out of the pot) connect everything back up and turn the key and it will run for about 15secs (wont tick over or rev up) then it'll die and not go again unless I repeat the process . Really losing heart with it .
Nice one on saving the coupe mate , really like these earlier coupes and silvers a win for me . Will be watching this thread and look forward to seeing your progress ! 8-)
ahh sounds like mine! I'm gonna have a play today if the rain dies down a bit,
cheers, its an older one so worth saving. even though this one is rusty and my black one isnt! it just feels better built and a bit more special. and the interior is MINT
I agree , both mine are west German built but there's something about my earlier one . If you sus out what the fault is gimme a shout , gonna have a do with mine in a bit see if I can sort it (its in the back of my mind the pooburg carb could be at fault although like yourself I've tried a few on it , just don't trust them , they're shite compared to the weber on my 1.0) 8-)
Will do!
Yeah I've tried my old one on it which i know worked, so i ruled carb out lol. Ill get onit
I'm gonna do exactly what i want to it, because its my car and dont care what you fags think of it! :lol:
Love you
you too babez xxx
right had a mess around, got it to idle again, but it still wont rev!
the coilpack was fucked so using my other one, changed the ht leads to different ones (made no difference)
and i put my electric fuel pump on it.
HALPPP I'm gonna put a help thread up in 2 mins, just uploading a video of it
g lader arb block came today! finally got a set! cant wait to see the difference they make.
also the engine... old school...
right, well i got the slam panel off of the black one by drilliing thee spot welds and levering it off with a screwdriver
off the car
damaged panel
half way through removal
getting there
also fiddled ith the ignition points, and got it running a little better.
more to come on my next day off! :)
Edited by erixtar1992
Nice one, I like this :) Is the daily gonna get the Derby headlights?
The engine looks like it could use some love!
it will indeed be running derby lights!
yeah man, gonna give it a coat of paint, aswell as cleaning up the bay. just ordered a new accuspark ignition points system aswell as new plugs ect. hopefully it will run properly!
getting there!!
drivers side of slam panel now bolted on :) need to drill the holes for passenger side. removable slam panel FTW
I thought this was blue :?
different one mate :)
You have more MK2s than me!
The blue ones not actually mine at the mo lol
IT LIVES!!!!
fitted an accuspark kit, got rid of the resistor wire so the coil is permanently running 12v, and advanced the timing. and it now revs up fine!
to anyone on here, i cant reccomend an accuspark kit enough! so simple!
its still hunting around a bit on idle, gonna try making a carb gasket tomorrow or something.
Whats accuspark?
it replaces the ignition points with a magnetic system, makes it alot more reliable, never have to adjust it, and you get a better spark!
Its for the older points system though right?
yes sirr, so for people with mechanical headed engines :)
Good to know. May need that for the 'other' engine :ninja:
