Just bought a 1.3 Mk3 Coupe (MK2F)
the Connection that connects to the ignition barrel isn't working properly. Is it worth disconnecting it and possibly re-soulding the connection or is there somewhere I can buy a new connection?
  • Views 895
Hmm, if the connection of the connection to the connection point isn't connected, then connecting a soldering iron would be worth a go if you have a soldering iron, but if soldering the connection to the connection to get a connection still doesn't seem to be connecting, then maybe someone on here could connect you to a connection shop that sells the connection for the connection you are looking for, so you can get the connection to the connection connected again.
Connection.
Connection.
i actually "lol"'d
Connection.
i actually "lol"'d
So will that make "it" or "you" connected ?
Connection.
Can I get a correction on the second reference to connection. I can't make the connection
Connection?
