1992 MK3 GT Coupe High Spec
Up for grabs is my 1992 MK3 Polo GT coupe in tornado red. I have had this car since February last year and it was stood until September 2011 whilst the build was under way.
TAX - 31/08/12
MOT - 30/08/12
MILEAGE - 216,000 ish
LOCATION - Hucknall/Nottingham just off junction 26 of the M1
Ideally looking for swaps with another MK3 GT Coupe that I can have my way with only light modifications, l or something Diesel and cheap to insure I'm only 20 :-D . But try me with anything you never know. if that fails 1,350 ovno
The reason I want to swap is like I said I didn't drive the car until September and so i didn't feel like i had got to know the car before it became what it is. I want something i can drive and get to know right the way through the modification feeling every little modification. Not just jump in and drive away.
Anyway enough crap about me beeing sad or ill which ever way you look at it... the car.
Good Points
- Ported and polished cylinder head and matching inlet manifold.
- De-wedged throttle body.
- Will come with Polo Ace 8k chip if it comes through (if not ill post).
- Richened mixture (performed by ex C and R technician).
- Newman Schrick 268/268 high lift cam shaft.
To go with the New head and cam:
- 8 new valves (re-cut and ground seats).
- 8 new valve guides.
- acid dip.
- 8 new followers.
- new cam oil seal.
- new distributor oil seal.
- new head gasket (wasn't gone beforehand).
- new rocker gasket.
- stainless steel 4-2-1 manifold and de-cat with lambda boss.
- full stainless steel custom made exhaust system.
- new BOSCH fuel pump.
- new fuel filter.
- new Volkswagen throttle position sensor.
- Golf GTI air flow metre (not yet fitted but does work).
- G40 polished Rocker cover (with custom Bolts and seals)
- Painted cylinder head and inlet manifold.
- new battery.
- reconditioned alternator.
- new plugs.
- new leads.
- new rotor arm.
- new distributor cap.
- new oil and filter.
- new black diamond grooved discs.
- new Mintex brake pads.
- new AP 60/50 lowering kit.
- new rear strut brace (not fitted).
- braided brake hoses.
- BBS G40 RA alloys in average condition.
- 4 new michilin energy saver tyres 165/65/ R 13 (costing well over 300).
- interior in good condition (apart from useual drivers bolster).
- CL wing mirrors.
- new drums
- new wheel bearings
- new Mintex shoes
- Genuine MK3 fog lights
- Halfords extreme brilliance head light bulbs and fog light bulbs.
- under sealed and all welding needed done at last MOT.
- Late spec rear lights
- new radiator
- new thermostat
- reconditioned bumpers and trim
- new timing belt
- water pump
- new auxiliary belt
Bad points
- dint above fuel cap Can't picture doesn't show properly but not terrible.
- a few pint chips on rear quarter not terrible either.
- knocks on full lock to the right I believe its the lock nut on the track rod.
- no anti rattle shims on front pads so clatter in reverse easy fix I have the shims.
- Squeeky rear axle bush i put the cd player on :-D. however easy fix and went threw last MOT with it.
- small dint in passengers wing again it doesn't really show on pics but is hardly noticeable.
- last owner got abit lively with a buffer and stripped a bit of paint on the bonnet.
All new parts fitted in September around 6,000 miles ago
This car pulls very well for a 1.3 it makes mince meat out of the usual rude-boy in his Corsa. Not 100% on the output as I've not had it tested but id say between 95-100bhp. it keeps up with a Audi A3 1.8t and a MK2 Golf GTI 8v cant catch it.
I have tried to be as honest as possible with this. Looking for a MK3 Coupe in white GT if possible. If not a diesel thats cheap on insurance. But again just try me you never know.
Pictures will try and get some better ones
Thanks Rob
The Car
Before lowering kit fitted sits alot better now
with a different exhaust and badges on etc
The Head
Before
After
The scratches on bonnet where it has like a lump in it hard to see
  • Replies 19
  • Views 1.5k
wish miles were lower and you were close would av done a deal on my nova
knocking on full lock now sorted turned out it was a wheel weight hitting the ARB. now balanced with sticky weights :-)
I like 6n's but can't really justify having one. Unless it was diesel as the insurance seems to be very high for me. So unfortunately I'll have to say no chap although it is a really nice motor and air con would be awesome GLWS/swap.
Thanks Rob
No probs mate cheers
Silver 1998 1.6 A3, easily manages 45mpg on the motorway, Insurance group is decent too!
Got any pics and a reg for insurance
298875_10150358172903188_510713187_80011304240_10150358173038188_510713187_80011
305786_10150358172998188_510713187_80011
309651_10150358173058188_510713187_80011
Now has badgeless grill on it.
Ssix20 XNF
Would this make the trip back to Scarborough?
Hows the interior? got any pics?
Edited by Knight_Bandit
Yeah it would, but unfortunately It's nearly a grand more on insurance. So I'll have to say no. Which is a shame really do like Audis
Thanks for the offer though
bloody hell a grand! Want the polo bad now! haha
As for pics I have some better ones that will go up before the weekend
would you be interested in my polo coupe? also howmeny miles has your polo done?
Got any more details chap pics specs engine etc and mine has 216,000 ish as i use it still
6n2 polo 1L on coilovers?
Swap for a 1l lupo on coilovers ??
swap for GT coupe, slight mods? needs a little work but nothing major? perfect start for project?
Got any pics and some more info chap could be interested
Have you still got this?
