mk2 polo steering spline
is the spline on a mk2 coupe s different so a mk2 bread? i bought a steering wheel and boss that came from a mk2 bread van but it won't fit mine, anything i can do? I've been told that knocking a ring off the spline makes it a mk1 golf spline and it should fit but I'm unsure, any ideas?
  • Replies 8
  • Views 2.6k
all polos have the same spline, but after a cetain year they are fitted with an adapter which makes it a bigger size.
if you boss is for a smaller spline and you have the bigger one, you should be able to remove it if you have patience.
if its the other way round then remove the big spline and fit to the car with smaller spline
ah right, I've been told removing the adaptor ring should sort it as that looks like whats in the way
yep remove it and it will be the same small spline as your other one probably has. they should pull off but some are harder than others.
hammer and a flat head to loosen it has been recommended, hope it works if not i may be steering wheel less
yeah should do. good luck!
red arrow
red arrow
sweet, this aint easy hah
