central locking stereo and cig lighter randomly died
I used my car last night and everything was fine but today i noticed the central locking didnt work then started the car and no stereo and tried to charge my phone but nothing i hsve checked the fuses and they are fine so now I'm stuck
  • Views 808
Bump :)
The Cig lighter and the stereo are normally on the same fuse, the central locking is then on a separate Fuse.
are there any other systems playing up?
Have you had any strange burning smells or wisps of smoke?
No nothing mate all was normal
This is only a possibility but I have had experiences of this myself..
If you've used a phone/satnav etc charger check there are no small bits of metal in or down the side of the cig lighter. Lower cost chargers usually do it!
Mine was shorting a while back in an ibiza with a little shard of 2mm metal lodged down the side.
Disconnect ciggy lighter and see of anything works, could be shorting things if there's something in it :)
