6n2 Central locking kit
Hi all,
I'm looking to get a remote central locking kit for my 6n2 16v! It has central locking on the key, however I want to have remote central locking!
Have looked at the kits but am unsure as to whether these are for car which have NO central locking at all! as when I put my key in and turn it all the doors unlock and i can hear the pumps! would these pumps need replacing with the ones from the kit?
Also they say about the transponder chips?!?!?! i just have a key with a light button on it lol
Any help accepted gratefully...
Edited by Funkyjord
  • Views 1.4k
The "Rclick" universal kit will interface with your existing key only central locking, they come with a replacement fob with a flip-out key that will need to be cut to your locks and the transponder chip removed from your key and put into the new keyfob or you can use it as just a fob and then you continue to use your original key
So no faffing around with wiring? very plug and play if you already have key central locking??? I wanted the switch blank thing with the blue LED...
The universal kit by the virtue of its name is universal to all car makes/models, so it's not plug n play, you have to wire it into your cars wiring, I think they also do a vehicle type kit that you unplug the connector from the pump and plug the new wiring into it and onto the pump.
Not sure about the colour of the LED, probably red, but you could go to Maplins and get a Blue one to replace it, would need the use of a soldering iron
Either way then, this will fit my car! lol. hopefully gunna get this next month if i can stop buying other things... hopefully the kit i get will just pop into the pump lol!
Whilst i have you here, do you know how a 6n2 gti splitter fits on to a 6n2 16v bumper??
4 6N0805903E spoiler front / GTI
4 6N0805903E B41 satin black
(4) 6N0805903D spoiler front /
(4) 6N0805903D B41 satin black /
Undo the screws at each end then it should unclip
Ah wicked. Thanks for your help mate!!!
