full beam stuck on
i removed the the part the indicator stalk is attached too so i could get too the spline adaptor easier and it wouldn't budge so i fitted my steering wheel back on , now my full beam is stuck on and the stalk works for the indicators but doesn't affect the lights, any ideas why?
  • Views 6.2k
I had a similar problem where I turned the high beam on and then it wouldn't go off lol.
Theres a little hook on the indicater stalk that pulls a slider up and down, this is what turns the high beam off and on, on mine the hook had jumped out of the groove on the slider, was just a case of teasing it back in
You can see the hook and slider just behind the stalk, no need to remove any thing
Hope this helps:))
Edited by Richman711
Hope this helps:))
a piece of plastic snapped off and i tried to glue it back on and now its fell in my foot well -.- but it didn't look like it moved, it was sort of hook shaped tho
Ye that hook is the the one of the back of the stalk, when u pull the stalk towards it pulls the slider up.
Take a pic of behind thw indicator stalk:))
