Debadge fading
I debadges the rear of my car a couple of weeks ago and you can still clearly see where the badge was , i was just wondering if theres anyway of getting rid of this only because i want to remove the side trim and thats oviously gonna be faded aswell :-(
  • Replies 14
  • Views 1.4k
i hate having to recommend it but a good t cut seems to bring an even colour back into paint. either that, or find some other decent polish.
I've already tried t-cut but it didnt work :-( yeah ill give it a decent polish when i have the time and see if it helps , do u reckon coloured polish may be better?
coloured polish will definitely help although youll probably want to do the whole car in it if it does work. i would say just get the boot lid resprayed but it wont be cheap and if the paint has faded youll never get an exact colour match. at worst perhaps cover it up?
ill have to have a look for light green polish , i dont really have the money to have the boot reprayed :lol: i suppose i could just put the badges bk on if nothing works
probably best. others may have better tips for you but if t cut didnt work then i dont know what to say as when it comes to fading in cars t cut has worked wonders for me. even if it does strip layers of paint away :ninja:
i thought id put a pic up of the problem....
Mine was like that ^^^ not quite as bad, but it came good with a machine mopping & G3 paste
Cheers ill give that a try when i have the money, how much is a machine polish roughly?
I got a Silverline multi speed from ebay £55 with three sponges and a lambs wool mop
Is there still a small amount of glue residue on there? Looks like there could be. If so, get hold of a toffee wheel and go over it gently, being careful not to burn through the paint. Then use the G3 cutting paste. Personally you dont need to machine polish it. If you are going to machine polish, use G10 cutting compound instead. Then polish and wax. You must add polish to any areas that have been 'cut' as it leaves the paint porous otherwise
+1
no i dont think there is , its completely smooth, cheers ill give that a try and if that doesnt work ill price up a boot repray i guess :-)
It's possible it's stained the paint. A cutting compound may remove it, or you could try wet and dry paper. You wouldn't need to respray the whole boot, just that corner
Cheer mate I've got loads of things to try :-p
