Where is the ECU in a 6n2?
Hi,
After hooking up my lappy to the diagnose the faults on my car, I seem to have some errors on the wiring for the ABS and Airbag modules.
The majority of the recommendations are to check the wiring to the ECU.
Where is it located in the 6n2?
Cheers.
!m!
  • Replies 39
  • Views 15.5k
Same place as the 6n :-)
Which is where?
!m!
Which is where?
!m!
Under the plastic cover at the back of the engine bay between the bulkhead and the base of the windscreen
Which is where?
!m!
Thank you...
I'm going to have a look this lunchtime and try to fix some of my ECU problems.
!m!
I presume it's on the drivers side?
!m!
!m!
Nearer the middle
The diagnosis plug is inside the car is it not?
He's already found that, read first post :lol:
Yes it is, but I'm talking about the actual ECU module.
!m!
FAIL! naa it was for my benefit :lol: i was ment to write its in the passengers footwell is it not. Need to check a mates mk5 tonight :-(
By the fusebox
The 6n is by the fusebox, the 6n2 one is under the ashtray in the center consol..
Just pull the ashtray up and its there!
I think it was said earlier...
Not the plug, the actual ECU module itself.
!m!
!m!
Item # 4
6n2s ecu is slightly off to passeneger side i think
By the fusebox
!m!
^ Yeah, I thought he was talking about the plug! Never minddddddd.
And yeah, it is...
!m!
Item # 4
Thanks for that.
Where does that pic come from?
I want that manual.
!m!
It's from ElsaWin around £25 on ebay
Just realised that previous pic is for the 6n so here's the 6n2 still item #4
Remove wiper arms and plastic rain tray. If you can see the ECU then you may want to visit the opticians :)
Thanks for the pointers.
Suggested fixes for the errors I am encountering seem to be to check the connections, replace the ecu modules or replace the loom.
This does not sound cheap.
!m!
!m!
What codes are you getting?
I am getting:
Tuesday, 28 February 2012, 21:58:31:0
VCDS-Lite Version: Release 1.0
Control Module Part Number: 1C0 909 601
Component and/or Version: 2A AIRBAG VW51 02
Software Coding: 12865
Work Shop Code: WSC 00788
3 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
01299 - Shareware Version. To Decode all DTCs
49-10 - Please Register/Activate - Intermittent
65535 - Shareware Version. To Decode all DTCs
00-00 - Please Register/Activate
Tuesday, 28 February 2012, 21:57:02:0
Control Module Part Number: 6X0 907 379 C
Component and/or Version: ABS/EDS 30 IE CAN V004
Software Coding: 05603
1 Fault Found:
01276 - ABS Hydraulic Pump (V64)
16-00 - Signal Outside Specifications
Have got an ABS pump coming soon, but the airbag stuff I'm not sure about the fix yet.
!m!
The airbag one is usually flagged cause the battery has been removed/discharged at one point?
You'll need the full version to clear it though.
And I bet the ABS one is because of a corroded fuse on the top of the battery tray. Actually, I bet the cost of the new pump! ;)
I have checked the fuses on the battery and they all seem okay but I will replace them and clean all the terminals first.
Also I have tried to clear the codes on the airbag and they just come back.
The shareware version still seems to let you clear fault codes. I did have one to do with the immobiliser that I cleared.
As for the price of a pump I was very lucky to get one off eBay for £25. Dealer price £685 + vat.
Can't agree to the bet though. I ain't that rich.
!m!
