Polo Sprint
  • Replies 29
  • Views 4.6k
Repost. But nonetheless, i lovely little car. I'd be interested to see what they did to the suspension up front to make it handle the power.
Oh, but where did you get the black and white photos from?
Edited by prankstar2003
Was looking at breadvans on google images and randomly stumbled across it
Actually think it's not bad looking, there's something about it lol. Definitely want one!
One thing though..
"With the top end continental-only Polo Coupé GT putting out 75bhp (the most powerful UK Polo was the 55bhp GL hatchback)"
We had the GT too? Or was this not in the UK when the Sprint was made?
we didn't have the mk2 GT in the uk.
Fair dos. Now I know!
Unless you're a pedant and count the Mk3 as a Mk2 :roll::lol:
But then it would be a mk2f so still no mk2 gt's :roll:
Now excuse me while I go and sit in my garden and call a Apple a Orange and then call anyone that questions my logic a pendant.
needing a 'like' button for comments such as that ^
Engine's in the back!
there was a TINY picture of this in PVW when they went to wolfsburg. Would of thought theyd show more of it considering how special it is.
Boxer engine in the back irrc?
I'd have though that would have done no favours for the understeer, bearing in mind there is now very little grip up front. Early subframe design?
Would love to see some interior pictures
I don't see that. If the stock set-up is strong enough to deal with the weight of an engine, it'r strong enough to handle the weight of a fuel tank and spare wheel.
Yeah it'll be light on the front with no fuel in it but i cant see it being bad, steering would be lovely and the arb should be enough to lift an inside wheel.
I ran an ally cylinder block, not quite the same.. but that gave me lighter steering, and grip was better if anything. I even ran this whilst carrying an AVY engine and gearbox in the boot! I don't recall any handling problems, but then my rear suspension was rather different to the Sprint's even if the front wasn't.
The car itself is a fantastic colour.
Ah right. I would just have thought with all that weight lost over the front, grip would be compromised. Maybe I'll move to rear engined mega- :lol::roll:
I've no experience of mid-engined cars, or any of the Polo's that have had the engine put in the back. But i haven't heard of them being known for understeer.
I think they're usually built to go in a straight line,though!
The main problem with the polo front suspension isn't really the design, its that the wrong wheels are being powered. Mk1/2 escorts use pretty much the same front end setup and they don't seem to do too badly. Taking the drive away from the front wheels would probably go some way to improving handling
VW-Audi weren't FWD specialists in 1970. Ford did the same design with their first FWD cars, before realising the way forward was gonna cost more money..
Peugeot didn't make such a bad job of the same concept when they fitted fundamentally the same design to their 205, though they had over ten years to improve things. But there are three little differences there..
1) It had a subframe, increasing rigidity over the whole set up.
2) The ARB/stabiliser bar was reverse mounted (so not bolted to the relatively weak crumple zone!). This also meant the loading wheel was pushed forward under braking or steering, instead of swinging back, making it more responsive.
3) It was also stable against side loads, which cause the driven front wheels to fight, thanks to a simple panhard-rod style linkage. Not as good as the independent arms with semi-floating ARB of the Golf ten years earlier, but still.
Edit - just to throw in a photo. Most 205/309's have the suspension on the right, the Gti had different arms (GTi version shown on the left with aftermarket polybushes)
Edited by MikeyMK
Mk1/2 Escort boys buy compression strut kits for the front end to triangulate the TCAs and create a wishbone style arrangement - same theory as the PPP Stage 3 subframe. Without the compression struts they have the same problem as the Polo with the strut moving fore/aft under any load.
The Pug 205 has wishbones from the factory, so doesn't have to rely on the ARB to hold everything together like an early Polo does.
Very true! Can I come and sit in your garden with you? I'll bring the fruit...
Chill out, I'm only messing. :?
Most had TCA's held by an ARB/stabiliser bar same as Polo, only the GTi's went on to be given wishbones (and no they don't fit Polos..).
Same design with 309, Visa, C15 van..
Plenty of examples online, they aint cheap either.
That old chestnut, we all know you're one of them..
