Couple of Problems (Polo MK2F)
I need a Bit of Advice / Pricing for a few parts / bits of work doing
New a new Ignition barrel connection (The actual connection not the ignition barrel)
Thermostat isn't working - Isn't showing temperature just stays at the asif their is no power to the dash. (Everything Else is fine)
Cigarette Lighter connection Re-wire
I've got a drip from my fuel tank. But I'm not sure If it's the Seal from the Half full of the tank or the actual filler cap. But when my car is under half a tank it doesn't leak.
If someone could help me out massively as I'm a newb to all of this car stuff. I would appreciate it alot.
  • Views 689
I was joking, please don't do this haha
:lol:
sounds like you have a rusty fuel filler neck. you can try getting some chemical metal from halfords and putting that on it to cover th hole. you use it the same sorta way as filler
What do you need help with exactly? Just call up your local motor factors for price on parts. To be honest mate if you're not very experienced with cars I wouldn't attempt doing it yourself. Have you not got any mates who are good with a spanner? Get them to do it, chuck them a few quid and watch and learn :)
