Project caddy for sale! ££££'s spent!
Here we have my project caddy for sale, I've owned this truck now for last cuple of years and i got it from my brother who used it as a daily....
really dont wanna sell this but needing a new work van is forcing sale as my old work van decided to blow a liner out last friday.... but anyway
good stuff...
the reason its so tatty is because I'm really into rats and i was guna be a rough and ready truck that was stupidly low...
comes with front coilovers, fairly new (cleaneed up and regreased once a year so they are free as a bird to adjust)
2 seat of 2inch lowering block as I've been riding it with 2 pairs in (to get the back right down)
new front discs and pads
full strip, clean up and ajust on rear brakes
comes with brand new set of tinted front light (propper ones tinted from factory inside and not me spraying them)
also comes with new front grille and headlight surrounds with chrome trim
assorted new parts like ball joints, track rod ends and bearings etc...
and old parts like trim, clips, bolts etc...
comes with propper caddy toe bar
now the expensive stuff...
I've had the front end body dropped, the engine was removed and the front suspension turrets were cut out and raised and rewelded back in so that the truck naturally sit lower with ajusting any coilovers...
also the drive shaft channels were chopped out abit and i had higher channels welded in
engine mounts also chopped out, raise and removed to stop any nasty sump damage
battery tray repositioned
gear linkages modified
while engine was out i also had brand new timing belt done (as it would have been rude not too)
rear axle flipped
also had custom U bolt made to fit in the 4inch blocks for both side at the back
also had new exhaust system from center section back
ALL WORK DONE BY FAIRBANK AND CRAVEN OF SCARBOROUGH (VW SPECIALISTS) RECIEPTS TO PROVE OF £2000+
bad bits....
obviously with it being off road and in storage for so long its gunna look like crap but i have spent alot of time and money on it
rear arches are rotton
too small bits of welding need duin on the sills (1 spot at each side)
a few bits missing like door cards, both bumpers, cd player, passenger door seals for windows
windscreen cracked and needs replacing
bodywork need attention but if the next owner want a rat truck then it will be perfect for them
all brakes serviced, coilovers regreased, inner arches undersealed, wings and doors sanded down ready for paint, door fully stripped and seal, runners etc all cleaned up and regreased
FOR MORE INFO OR TO ARRANGE A VIEWING CALL ME ON 07715279832 (LOOKIN FOR OFFERS AROUND £600) THANKS GUYS... link to pics below
http://www.flickr.com/photos/68191574@N08/
  • Views 516
hello mate really interested in this, could you put a pic up of the whole car as its being sold...... thanks
i will try get 1 up tommorow mate... forgot to say its sorned at the mo and will needs toein or trailering away and i will post millege up tomorow also, located near hull and engine is 1600 deisel
now advertised on caddy forum aswell, more pics coming soon
