how do i remove key barrel
I'm changing key barrel on me mates audi 80 coupe but cant see how to release it from the houseing.
Does anyone have any ideas?
  • Views 1.5k
Hi, this is my first ever post on a forum, so forgive me if it looks a bit odd!!
I recently swapped out the tailgate lock on my 2001 Polo GTI, if the Audi is similar then there should be a spring & circlip on thhe back end of the barrel housing, despess this & remove the circlip. insert the key into the lock, hold the housing & turn the key till it stops. Now you should be able to pull out the barrel from the housing.
Tip dont take the key out of the barrel until you have it in the new housing as the key retains all the lock tumblers!!
Hope this helps
The above is excellent advice for the tail gate lock, but I got the impression that you were talking about the ignition barrel.
If this IS the case, then, for reasons of security, the barrel is part of the steering lock, it is possible to drill the lock, depress the plunger and remove the barrel and even fit a replacement.
The problem is that you have then removed a layer of security from the car.
Regards.
