lots of performance and G40 parts for sale
G40 ISV - £30
G40 Throttle Body £50
G40 Alternator - £40
G40 Front Grill Badge £25 (fins broken off back)
G40 Front Grill Badge £35 (all fins OK)
G40 Rear badge (Missing Pol so says oG40) - £25
G40 Inlet Manifold x 2 - £30 (each)
G40 Exhaust Manifold - £30
G40 ECU with 250kpa MAP sensor fitted - £140
G40 Driveshafts complete with CV's - £80
G40 ATV Gearbox - Recently rebuilt by previous owner, not run since - £300
Piper 272 Cam - New, fitted but engine has not been run - £150
Rover Intercooler - £25
Mk1 Golf GTI Oil Cooler & Lines/Mounting Bracket and Oil filter housing (the housing is 8v gti specific, you will need a sandwich plate for operation in a polo) - £20
front lower strut brace - new - £25
rear lower strut brace - new - £25
Powerflex? (Purple) ARB Bushes - £20
Porsche 944 speedometer - £25
Porsche 944 dash console - £25
VDO oil temp guage - £20
VDO oil pressure guage - £20
VDO volts guage - £20
Cheapo Boost Guage - £10
Mk2-3 Single Wiper Conversion - £50
RPM Stage 2 Power Kit (Chip + 68mm Twin V-Belt Pulley) £80
Lucas 54 Calipers stripped for powdercoating + seals + pistons and bolts (no carriers) - £40
63mm iirc oil pressure gauge nos - £15
VW Polo and Lupo OEM watercooled oil coolers. - £20 each ( 2 avail )
Brand new mini radiator (top fill) - £20
G40 Clutch & Pressure Plate - £30
Helix Paddle Clutch (Friction Plate only) near new - £150
15x7 and 15x8 Borbet BS with 195/45/15 Eagle F1 Tyres - £400
Cobra Fixed Back Bucket seats - £130 for the pair
Lots more bits to list as I catalog parts at the unit
Prices do not include postage, collection is preferred. I am in Central Manchester but travel to Bolton, Macclesfield, Derby, Northampton regularly so may be able to deliver bits en route
cheers,
Saf
  • Replies 25
  • Views 817
also got
1.4 vw engine cover (with brackets) - 35
1.0 vw engine cover (with brackets) - 35
6n Smooth Rocker Cover x 2 - 25 each
6n Smooth Rocker Cover (with tb cut out) - 20
Large FMIC (will get measurements) new - 80
G40 TCA - Brand new - offers over £120
Several front anti roll bars - collection only 15 quid
Chrome Bumpers - Mk1 Polo - Damaged - 80 for pair
Momo Team 300mm, new, horn press and all fittings - 120
ATV, Piper Cam & G40 Front Badge (no missing tabs) sold
helix friction plate no longer for sale
Do you have pics of the lupo/polo OEM oil coolers?
Sound. That works out well as i need to remove the suspension currently on the car for some guy this week. Don't really want the car on bricks for too long :lol:
What an i actually picking up from you? haha!
kw kit with front struts and top mounts (with lowering top caps fitted)
abd rods/machined pistons/crank
two dunlop 185/50/14 tyres
I cannae find it in that album :?
Thought so
Edited by prankstar2003
my bad
Does the water flow into the metal pipes then? Any idea how these compare to a traditional oil cooler?
yeah flows with the engine, will help warm engine up quicker, and keep oil at a more stable temperature, compared to no oil cooler, and helps where there is no airflow through the oil cooler (ie hooning it on the motorway and then getting stuck in stop start traffic)
i never ran them on my engines, as I have external oil coolers fitted on all my cars
Any chance you've got a gt airbox?
I was looking to buy a mocal heat exchanger (or have one made by a mate) and they work on the same principle. I spoke to a motorsport fella who builds engines and he said the exchangers work better for the reasons you mention there, as well as keeping water and oil temps more inline. I just wonder about the effect on the cooling system, and whether the heat exchange surface is large enough
How do they fit onto the block btw?
Only got a spare g40 air box mate sorry.
My water heats up quickly but stays quite stable. Oil temps stay relatively stable, hasn't cooked the oil or toasted the water yet and that's with turbo water cooling.
Either or really, might make a tidier bay with one fitted rather than beefy lines going all the way to the front panel or wings for your oil cooler.
It mounts where the oil filter does, there is a larger threaded stud for the oil filter, this sandwiches in between and locks in place with a nut. Lines normally run to the pipe at back of engine and in the thermostat housing ( one port is blocked off on mk4s and the mk5 gtis have the oil cooler return fitted as well as the multifunction temp plug )
I figured they attached there. The tidy bay is attractive. May look into a larger rad too as it will need to cool a turbo, as well as oil sprayed onto the pistons (1W what?). Bring one with you if you want, and I'll have it from you if thats cool. Cash on collection ok?
ARB bushes? inner or outer, new or old? pictures. Thanks.
neither, clues in the name, ARB bushes...
they are purple powerflex bushes, I'm sure they are in the link to pictures on the first page...
as new, bit grubby, unpackaged, were fitted but never used
Sorry what a tard, bad day! if you have any lower arm bushes give me a shout. Tommy.
what condition is the G40 clutch in? new? used?
and how much would postage to leamington spa, CV31, be?
cheers,
George
is the g40 exhaust manifold a 4 branch mate??
cheers tom
The g40 ex mani is standard...
Clutch is is good nick but is 2nd hand!
Was the ATV gearbox rebuild a home diy job? Or a pro job?
Sold now I'm afraid, was told it was pro
Will do Tom lad, might see you around next time I'm in d town!
