Buying paint?
So I need to get my hands on some paint, I believe my coupe is pearl grey metallic? Let me know if I'm wrong please as I can't find the paint code on it.
Where would I get some from? Thanks, slim.
  • Views 928
Morley's on Ozzy Rd or VRS on Alfreton Rd. Morley's are friendlier at doing small amounts though and not adversed to taking their chips out to the car if you ask nicely (that or take your fuel flap in). I'm told Bestwicks will mix aerosols but I've never tried them myself.
Not sure now as ideally I would want it in aerosol form. I thought it would be stocked, I mean how close can they get by mixing it?
MY CAR HAS NO REVERSE RAKE BTW!
No paint supplier will have colours readily stocked. They'll only have bases and tinters there which they'll mix to spec depending on the brands of paint they stock.
Usually colour matches are pretty good, more so if they can match a colour chip against a panel on your car, but theres plenty of variables to take into consideration, such as has the car been painted before, has the existing paint oxidised or faded, the type of paint used, water-based, aerosol or 2k for example and sometimes the air pressure at which the paint is applied can affect a metallic finish, as can heat.
