CEG 085 5 speed refurbed gearbox
I have a CEG 5 speed gearbox for sale. with 5 speed ARB and 5 Speed gear linkage
Looking for £130 for it all so its a full 5 speed conversion for your car everything you need
i have replaced:
differential bearings and seals
gear selector shaft seal and bush
filled with good grade oil
I have also machined down the flanges to remove all of the play they had so it now runs perfect.
Had all the diff checked by my local transmission place to makesure it was all ok and checked the rest of the insides and they looked and worked fine so just replaced the other bits listed
the gear linkage has had a full new bushing kit fitted too
located in Corby, Northants.
could possibly courier or you can arrange your own
all off the car and ready to go
Edited by StinkyPete
  • Replies 15
  • Views 984
Looking for £120
i have replaced:
Had all the diff checked by my local transmission place to makesure it was all ok and checked the rest of the insides and they looked and worked fine so just replaced the other bits listed.
Also have the 5 speed arb and gear linkage will do both of these for £30
G lader blocks £50
all collection at these prices and located in Corby, Northants.
Still on the car atm but can strip off when wanted
lots of other bits for sale too will list separately
how much for blocks posted
cheers
would do £55 posted mate 1st class recorded if that sounds good
yer sounds good.
pm me your details pay pal ok
would u just do the linkage and how much for posted if so? cheers
Hey I would do the linkage £20 posted that sound good
Glader Blocks now sold
CEG ratios & final drive?
i dont know but I've heard its next best thing after an ATV box mate if you search on here there is a post with alot of the gearbox drive ratios on
yeah i think thats just 6n and 6n2 but then again i didnt look in that much detail. ATV is g40 isnt it?
this is a CEG off a mk2f so its a better box and yeah ATV is G40 heard people use the CEG on thir G40's if they cant source another ATV and found the ratios here they are:
First drive: 3.455
second: 1.958
Third: 1.25
Fourth: 0.891
Fifth: 0.74
Final Drive: 4.063
there are boxes closer to the G40 than this but they maybe harder to get hold of this box work amazingly well on my carbed and lightened/balanced AFH
are you interested in it Harris
let me just do some calcs and compare to what i have at the minute, although that final drive is looking quite revvy so maybe ideal?! and i maybe yes, depends if it will fit my mk4 actually ? haha
it will be a straight fit on your engine mate but if you want a lighter mk3 flywheel thats lightened and balanced with clutch and the rare slim starter motorthats needed i also have these for sale they may benefit your engine and i can sell these with it too if your interested
Iv just worked out the ratios of my 1.4 box, the 1.6 box, your 8p, and my 1.4 final drive in the 1.6 box.
You got an email i can send it to?
mine isnt an 8P box its a CEG but they are both 085 type boxes i think with the same ratios
and my email is pjdirtjumper@yahoo.co.uk
bump new info and price
will get pics tomoz or tuesday box is all painted too
