Help! 9n bonnet bra
Hey all, can somebody please help and tell me the best way to fit a 9n bonnet bra? I just keep getting creases around the edge of the bonnet where the lights are :( thank you.
  • Views 1k
Unfortunately you will always get them creases ! But the best way to fit is cross the two edge straps over and then tighten the middle one, over time it becomes a better fit, but the creases will always be there
Thanks but what do you mean cross over, I cant find anywhere to put the clips other than clipped over the sedge of the bonnet at the windscreen. Can you please reply and help me on this one :)
You should have bracing on your bonnet on the inside part (unless you have a bit of noise absorbant material, in which case you'll have to remove it or cut holes in it) on this bracing there is many holes and slots, what I mean is cross the straps over (to make an x shape) and then attach to the furthest away hole or slot, I hope you understand, its really hard to explain
Yeah I understand now. Yeah I also have sound deadening on the underside of the bonnet. Time to remove that tomorrow :) Thanks.
