1.1 AAU TO 1.3 AAV
Hello , I have searched the FAQ but cant find the answear i need.
Could some one tell me if i swap AAU 1100CC for a 1300cc AAV engine what else do i need to change ie 1300 ecu , do i need to change the wiring loom ?
and are the gearboxes the same .
Many Thanks :-) :-)
  • Views 1.2k
I'm looking at doing this.
I think you need to change the inlet manifold, injector unit and ECU.
Wiring loom is the same, gearbox and clutch will fit.
Anyone else actually done the conversion?
Yes I know someone who's done the conversion. You can also do it with the ABD, (1.4) ABU and AEA (both 1.6) engines but the ECU from these is a bit different, but the basic wiring is the same for all.
do you know if the engine and gear box mounts are all in the same place or do you need to modify.
