9n bump strip removal
Are they glued or pinned? Or stuck on poppers? Also how do they remove?
  • Views 1k
Sides are held on with adhesive and simply pry them off, they also have 3-4 aligning points on it which go into the body (they do not clip in or anything, purely for aligning the bump strip) and front and back mouldings clip in, start prying at one end and work your way along, but on the rear, remove number plate lights first
Hope that helps buddy
If they leave a flush/smooth look I'm going to remove my side ones at the weekend. Thanks
if you do could you get your pics up on here? i fancy doing it to mine
Yeah sure :)
they wont leave a smooth look as they have holes behind them, if your wanting to de stripe your car then youll have to have the holes welded up and filled over
