Will they fit!
Wondering if any one knows weather id get 15x8 on 6n with no arch work and what ET would be best
30 all round
35 front 30 back
35 all round
Never mind the arches. You might not clear the struts with that offset and width.
I can just clear the struts with 8J 52 offset with 15mm spacers, so I'm guessing maybe JUST?!
Depends on what tyres you go for really.
Depend how much camber you have with strut clearance.
I have 15x7.5 et25 and -2.5 degrees and there's about 8mm between adjuster rings/spring and the tyre/rim
Standard vw is et38, so I cant see an issue. Go 175/50 to avoid scrubbing front wheels have a wider track than the back, so something to bare in mind.
They ain't standard vw wheels. They are 8 inch wide. Once you get to that width, the offset causes as much problem on the strut side as the arch side
ET32 on the rear or less (ET30)
Fronts are gonna need to be about ET30 or less to clear (ET25)
Your gonna need 165/50's or 185/45's mind to get those under the arches
