smoothing mk2f bumpers
the bumpers on my coupe are looking a bit tired and I've decided i want to make them completely smooth, how do i go about this? Is it just a case of apply filler then sand it smooth? Or is that not how its done? Thanks in advance for any help
  • Views 918
i what way are yo wanting to make them smooth? do you mean get rid of the dimpled plastic effect or are you wanting to smooth recesses out? either way you will need to use either a plastic primer and/or plastic filler to adheer to your bumper.
dimmple removeal- there are different ways around doing this but all comes down to personal preferance, i personaly red scotch with a solvent based degreaser then plastic prime followed by 3coats of high build primer, leave the primer to cure then flatt back and apply another 2 good coats of high build,leave to cure then wet flatt ready for paint, try not to break through when flatting.
recess removal- red scotch with solvent degreaser around the area you smoothing, then 180 sand the area, apply you filler as needed, sanding as needed, if you feel you need to platic weld a piece in for any reason then do so before yo start filling, then follow the instructions as above before painting the bumper (unless you wanting to keep your texture look in which case simply repaint with texture coat)
