will i need a spring compressor?
right i have got the coilies for my 6N. this is probably a stooooopid question but will i need spring compressors when swapping the old with the coilies?
this thread on uk-polos-net doesnt mention it http://www.tigerstyle.co.uk/phpBB3/viewtop...=10&t=33186
but my dad n mate think il need one?
  • Replies 19
  • Views 1.2k
if you are reusing your top mounts, yes
yes unles your stupid like i was,, thick gloves and an angle grinder.. worked tho!
You could get away with not using them if you're safe and think it through or improvise
well i dont really know what I'm doing... the only dampers n springs iv ever taken off are off the starlet and sciecento at college n thats just undo the three bolts at the top then the two at the bottom and that was it :lol:
I didnt use them when doing the coil overs on mine, just made sure I pointed it away from my face and any cars. It didnt really come of too dramatically either
hmmm I'm not sure whether to risk doing it without one or not... :\
Just undo the bolt slowly and you'll be fine
Or even for the last turns of the thread put it on the floor an drop stuff on the grips to turn it
I'm assuming 6n suspension is similar to 6n2
Don't need one, just undo the top nuts/fittings with the car on the ground and they'll dismantle as you jack it up (car's weight acts as the compressor).
You only need to take apart not put together.
You could always put a ratchet strap or 2 round the spring before removing the nut so it expands minimal amounts.
Don't try holding down with your hands, you'll likely get smashed in the face with a top mount
True that mikey, remove your top nut and plate, then the top mount nut all with car on floor, then jack up
cheers for all the help guys! if it stops raining then il try n give it a go today!
+1 for Mikeys suggestion
thanks for all the help, will be putting them on next weekend!
good luck!
Funny that. I was just talking about this very same subject, and was going to ask the very same question. But its already been answered (and asked) for me :-D
for the sake of a tenner may aswell just buy sum :lol:
Cables ties..... :)
my dads got some ratchet straps so I'm gonna use them n losen the top bolts off n then jack it up slowly :D
You won't need ratchet straps. Take both top nuts off and jack car up.
